I've pretty much decided that for the most part my 1999 FRC will remain stock, but when having my oil changed today they checked out my filter and it is pretty bad, so I just went into the mall section and bought the K&N. I know most of the time the hp additions for such minor mods are false and just a hype for the product, but will there be any thing I will notice between my new K&N drop in and my old crappy filter? The main reason I bought the K&N is because, first, I trust the company, and second, it is washable and I don't have to throw it away like the piece of crap paper thing in there right now.
This was the first mod I did to mine, except I went with the cutout shroud, and I definately noticed a pick up. I suggest either cutting a square out of the shroud cover over the filter, or doing the tie-wrap mod. If you want to see what the difference would be, just take the cover off and drive around the block. Dont hit it to hard, you might make the filter jump out! Actually that would be more likely on a hard brake. But just spin it around the block that way, if you dont feel a difference (i cant imagine that), then just put the cover back on. :thumbs:
Even if it gave you 10hp over stock (which it certainly does not!), it wouldn't be worth it considering the amount of dirt the K&N lets into the engine. Here is a quote from someone I know who is an expert on oil analysis:
Don't be lulled into false security just because spectrographic analysis
indicated no increase in silicon. Spectro only analyzes components of 5
microns and under, thus some of the larger dirt particles would not register
with spectro. I can assure you that if you ran a particle count/ferrography
you would see a significant difference in the +5 micron components with
either a foam or OEM paper element.. Every tractor/trailer on the highway
run paper elements. Every CAT or other commercial engined off-highway
machine run paper elements.. Rasons: they work.. Very well.... If a K&N
worked better, they would be on every major piece of equipment in the
world.. It is that simple.. On your next oil analysis, check "run particle
count". Then switch to a paper element and do the same test, again.... You
will be amazed with what you discover....
George Morrison, STLE CLS
So why risk it? Stick with the OEM paper air filter, it does a great job of trapping dirt, which means your engine will live a much longer life than if you ran the K&N.
This is not true. Effectiveness is not the main, nor is it even close to the top of the list of reasons that manufacturers choose products. Their choices, for the most part, are based on availability, cost-effectiveness and especially bids. They install paper filters because they're cheap, easily manufactured and widely available.
Don't get me wrong. I'm not stating that this study or test is faulty, only the reasoning that manufacturers install certain parts because they possess the highest quality and effectiveness. If this were true, manufacturers would install forged pistons, full roller rocker arms, roller camshafts, synthetic oils, etc, etc. in their engines because of their efficiency and durability. We know these types of parts are not widely used because of their cost to the manufacturers. Why would GM mount run craps when most, and I'm sure GM, believe there are far superior tires for less money out there? Because Goodyear had the lowest bid to supply tires in the required sizes and quantities. Chris
You're missing George's point though. He's talking about how trucking companies do not use K&N air filters, and they obviously have the choice of putting whatever they want onto their fleet in order to maximize their durability and cost effectiveness. This is why you see so many large trucks running bypass oil filters and synthetic oil, that way they save hundreds of dollars on oil changes, along with extending the life of their engines. So if these trucking companies all felt K&N air filters would extend the lives of their engines and save them money as opposed to paper, they would use them. Think about how much money they would save if they could go with an air filter that never needed to be replaced, but yet they refuse to use such a filter. Why? Because they know it will reduce the life of their engines, that's why they continue using throwaway paper air filters.
Your best bang for the buck would be to swap out your oem airbox lid for a ZO6 oem lid (02 or later) and drop in your K&N filter. Still looks factory oem and increases the breathability. Not an expensive mod and you'll like the results. In addition, try adding the hood seal to keep out debris and additional condensation. I liked the performance results in my 99.
Couldn't agree more. I've seen too many analysis where the K&N passed more stuff when new and got worse with age. IMO it is an investment with no upside.
Also have never seen a definitive test hwere the K&N increased the HP on a C5.
Having said all of this I do like their oil filter for the C5.
Not sure if this falls within your definition, but here is an example of a K&N and it's effect on my Z06. The bottom graph is my car stock with the K&N zip tie. The top graph is my car stock with the K&N and LS1-edit tuning. With the K&N filter in place my car became extremely rich (10.0:1 from 4000 rpm up). The tuning leaned the A/F mixture among other things and the result was the top graph. Also, before tune mpg average was 18 hwy after it was 28.
Great choice :thumbs: I went with the K&N FIPK system. When you start your modding check it out. It comes with a bigger air bridge too :cheers:
This system has been proven to add 16.9 RWHP - highly recommended!
Regarding K&N filters: I've been using them now for more than 18 years and have never had any oil-related issues. You'd think that after all these years, tens of thousands of car (and truck) users would be screaming if their K&Ns were causing premature engine failures.
My advice? Take everything you hear with a grain of salt. If the statement(s) is fairly isolated, then there's a good chance that it is false or misinterpreted.
I am too have the K&N FIPK gen II System, and got serious gain in HP and Sound. However, i always thought this kind of filters are doing a BETTER job than the paper filter element. Can Somebody post more infos about this (That they might harm the engine) ? I dont panic about the filter, but dont want to risk my engine.
But before i change anything, would like to hear some more opinions, and maybe some serious facts !
Thanks,
Hallo Jochen!
Wie geht's denn so in Bayern diese Tage?
Viele Gruesse von einem gebuehrtigen Hamburger der seit 14 Jahren in den USA lebt.
Thanks,
Thanks,
This was my first mod on my '99. When I first installed it, I couldn't really feel a difference. But, then I cut open my air box with a Dremel and I could really feel a difference. :cheers:
Based upon what I have read here and on the external link, The K&N will perform better and keep your oil cleanif you clean and charge it every time you change your oil. Not so much to ask from someone who loves their car. I know that K&N says every 50,000 miles (or sooner in dusty conditions), but I love my car and I love horsepower and fuel economy, so I clean mine every time I change my oil. If I had to be buy paper filters that often, I would be spending a lot more money.
