Allow TCC lock duing shift???
Now can soneone explain to me the reason the older C5s lock the converter during shifts while the newer C5s do not? I am speculating that GM may have changed this due to possible wear and tear issues with the transmission, but I am unsure.
What are the trade-offs for locking vs. unlocking the converter during shifts?
Which option is better for performance?
For those that have LS1 Edit... What setting are you using?
My post from a performance point of view is best suited for this section of the forum I believe. Surely someone out here should know enough to provide more insight on this topic. :confused:
The reason I think it isn't locked during shifts is the shutter or judder or little pulsing you might feel with the TCC locked. The TC is a good shock absorber for engine/transmission torsional vibrations. If I recall, there was a time when some highend GM automatics actually had a very small bit of slippage programmed into a locked up TC; maybe 1/2% or less, just to smooth out engine vibs at cruise. It wasn't enough to generate excessive heat or wear.
As far as transmission loading, TCC only locks during part throttle, right? It's not a factor in WOT shifts unless you are able to change the programming.
I think harsh WOT shifts would easily overload a TCC.
The TCC is a wet clutch roughly 13-14" in dia. and only see's engine torque no matter what gear your in or what your speed. :D
Back in the 80's I did some work with the Corvette Development group at MPG and we found the best 1/4 mile times were obtained by locking the TCC at 3000 rpm in 1st gear! :eek:
The problem with this is after several runs the transmission would fail hard parts, like the input housing or planetary gears, sun gear drive shell etc.
TCC was locked during a shift to minimize the distirbance of the transmission.
As I understand it the A4 will not up shift into 4th at WOT nor will it lock the TCC.
Only Ed Wright programming will provide this feature as far as I know. :D
