Dead Optima
Old Feb 5, 2004 | 04:30 PM
99SilverC5Coupe's Avatar
99SilverC5Coupe
Default Dead Optima
I hadn't had my car out in 3 weeks plus... needed to move it to get it up on jackstands and my Optima red top didn't have the power to crank her over.... Any tips or cautions on charging it? I've read of some folks burning them up :eek:
I've got an old charger that says it charges at 6 amps. Is it safe to use?
:cheers:
Old Feb 5, 2004 | 04:45 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Default Re: Dead Optima (99SilverC5Coupe)
I've ran my red top optima down several times to where it wouldn't crank car over.
Usually happens in the winter months when installing mods and leaving key on or playing stereo too long, etc.
I know this isn't good for any battery but it happens.
I always charge it back up with 10 amp charger set on the sealed/gel setting.
Haven't had any problems.
I have read that its not good to slow charge these type of batteries, though.
Old Feb 5, 2004 | 04:49 PM
MC TORCH RED's Avatar
MC TORCH RED
Default Re: Dead Optima (Z06-JIM)
damn great looking z jim.. :eek:
Old Feb 5, 2004 | 04:56 PM
Z06-JIM's Avatar
Z06-JIM
Default Re: Dead Optima (MC TORCH RED)
Thanks! Nice looking coupe you have there too!
Old Feb 5, 2004 | 07:29 PM
c5freak's Avatar
c5freak
2 words: Battery Tender. :thumbs:
Old Feb 5, 2004 | 08:28 PM
97C5ENVY's Avatar
97C5ENVY
I accidently did the same thing (didn't run the car for over 3 weeks and my Optima Red top didn't have enough juice to crank engine), doing this actually damaged my battery though. Luckily I only had the battery for 2.7 years and still had a few months left on the "3 YEAR FREE REPLACEMENT WARANTY", so I took it to my local Advance Auto and they charged it & ran a load test on it and sure enough battery had a bad cell. So I walked out with a brand new Optim Red Top in hand for free. :D :cheers:
Old Feb 5, 2004 | 10:04 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Big Jess flashbacks MC".
:eek: :eek: :steering: :lol: :lol: :nopity
Old Feb 5, 2004 | 10:13 PM
LittleBoyBlu99
Default Re: Dead Optima (97C5ENVY)
I had a Red top that lasted about 6 wks and started losing charge . I made the mistake of boosting it of with my other car and it soon went dead so I took it back to Battery Plus and they gave me a new Yellow Top and it has worked great for 2yrs now. :cheers:
Old Feb 5, 2004 | 10:20 PM
LittleBoyBlu99
:nonod: Next time he needs to clean those dirty chrome rims. :lol: :p: :auto: :seeya
Old Feb 5, 2004 | 11:24 PM
Dave68's Avatar
Dave68
AGM batteries like fairly-high current when being charged. 6 amps is probably the minimum current you'd want to use. Optimum is about 20 amps. Be sure to use an automatic charger.
Old Feb 7, 2004 | 07:57 PM
hermit's Avatar
hermit
I've got the product sheet for the Optima red top in front of me and it says suggested charging rates are as follows. Battery charger(constant voltage): 13.8 to 15 volts, 10 amps MAXIMUM, 8-10 hours. Rapid recharge (constant voltage):Max voltage 15.6, no current limit as long as temperature stays below 125* F. Charge until current drops below 1 amp. Float charge: 13.2 to 13.8 volts, 1 amp max. When using a constant voltage charger, amperage will taper down as the battery becomes recharged. When amperage drops below 1 amp the battery will be close to fully charged.
To Dead Optima
