removing catalytic convertor
Old Feb 28, 2004 | 04:59 PM
addicted to race's Avatar
addicted to race
Default removing catalytic convertor
what is the effect of removed the catalytic convertor on acceleration? :seeya
Old Feb 28, 2004 | 06:26 PM
OGC5's Avatar
OGC5
Default Re: removing catalytic convertor ?
On a Street Car-not much performance gain plus IM TRYING TO BREATHE AS MUCH CLEAR AIR AS POSSIBLE!
:nonod: OGC5
See Ya :steering:
Old Feb 28, 2004 | 11:13 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: removing catalytic convertor ? (OGC5)
Unless you have a really pumped up engine (bored and stroked or pumped) you will only see 5 maybe 10 HP if anything! What you will see (SMELL) is a lot more un-burned fuel and hydrocarbons!!! The smell can get so bad that some people have reinstalled the CATS!!
BC
Old Feb 28, 2004 | 11:54 PM
nosturbo's Avatar
nosturbo
Default Re: removing catalytic convertor (addicted to race)
it's not worth the work, and the smell is so bad it'll always stick on your clothes. If you have a turbo-charged engine that would be a different story. I used to have a Supra Twin Turbo, and it picked up a lot of power after I removed the cats.
[Modified by nosturbo, 4:55 AM 2/29/2004]
Old Feb 29, 2004 | 12:05 AM
fsuforever's Avatar
fsuforever
Default Re: removing catalytic convertor (nosturbo)
If you plan on going with a blower the cats being removed will help the motor breathe easier i had 3inch exhaust & a vortech b trim long tube headers on a 302 & it was nasty @wot btw i have no cats on my vette right now & i have no burnt gas smell on my clothes nor does it smell in the car .If your outside the car while running you will notice a gas burn smell as far as the gains on a modded car it will be more than if you had cats on it.Then you have to ask yourself can you handle the tone thru out all the rpm levels that you will be running your car .btw It will be loud if you run no cats thru lg tubes & a aftermarket catback
To removing catalytic convertor
