Blackwing Performance
Old Mar 2, 2004 | 12:23 AM
imelectric's Avatar
imelectric
1st Gear
Default Blackwing Performance
Just bought my '02 Pewter A4 on 1/23/04. Beautiful car, but 2.73 gear sucks. Last Friday installed Blackwing + TB bypass. Sure was hard getting the star bolts back in at the front of the filter. Anyone have tool suggestions? Today I used GTech Pro to record 4.88 0-60 & 13.23 in 1/4; good launch; cool day. These #'s are nearly identical to pre Blackwing test. Might have picked up .05 in the 1/4. Does anyone have verified gains from the Blackwing? Not flaming the filter. It is a high quality piece, and I'm fairly certain it keeps more dirt out of the engine than stock.
Old Mar 2, 2004 | 12:50 AM
99 MagRedVette's Avatar
99 MagRedVette
Default Re: Blackwing Performance (imelectric)
My baseline run on my stock C5 M6 netted me 263 HP @ 5460 RPM & 281 ft-lb @ 4000 RPM (at around 75 mph) on the G-Tech. I've since added a Blackwing but haven't made a followup run. There's no straightaway long enough around here to do a 1/4 mile run without attracting too much attention, so I don't have 1/4 mile times. What did you see for max HP & Torque? I'll post my followup run when I have it...
[Modified by 99 MagRedVette, 9:51 PM 3/1/2004]
Old Mar 2, 2004 | 12:59 AM
CORTVET's Avatar
CORTVET
From: Putting a 50¢ sticker of the U.S. Flag on a $50,000 import does not make one a patriot.
The G-TECH PRO is nice, but it is not that accurate. I would not trust the numbers of it that much.
Get it on a dyno, if you want more accurate HP results.
AZC5
BTW- welcome to the forum.
Old Mar 2, 2004 | 01:05 AM
LBear's Avatar
LBear
Default Re: Blackwing Performance (AZC5)
Actually the G-Tech is within 1/10th of a second accuracy.
Old Mar 2, 2004 | 01:08 AM
99 MagRedVette
Thanks, AZC5! This is a great forum! :)
Yea, it's a fun toy and I had been using the GTech to see what effect various mods do on my other cars. Just got the C5 a month ago and had to run it. The GTech is very consistant in its readings; my 95 Tahoe reads 117 HP consistanly over 6 runs at about 65 mph. My two runs with the C5 were 261 and 259 HP (one run in each direction in 2nd gear to 6000 RPM)...
Old Mar 2, 2004 | 01:13 AM
CORTVET's Avatar
CORTVET
Default Re: Blackwing Performance (99 MagRedVette)
I have a g-tech pro, and it is pretty accurate for times, but it is not that great for measuring HP.
My HP & TQ numbers are very different on the dyno, versus the g-tech.
0-60, 1/4mi = G-Tech pro is pretty accurate.
HP, TQ = G-Tech is not as accurate as a dyno.
In other words, dont tune with a G-Tech, tune on a dyno. Better results.
AZC5
Old Mar 2, 2004 | 01:21 AM
99 MagRedVette
AZC5 :iagree:
I just use it for general trend data.
BTW: have you had your Vette dyno tuned? What were the results? Is it worth getting a stock C5 dyno tuned? What kind of improvement should I expect? Thanks!!!
Old Mar 2, 2004 | 01:28 AM
CORTVET's Avatar
CORTVET
I am willing to bet that you are putting more HP to the ground than that. Stock, they usually put out about 290-300rwhp.
As far as a Dyno tune, I bet you can squeeze some more out of it. Some people get as much as 20rwhp from it. Some see less.
AZC5
Old Mar 2, 2004 | 01:31 AM
BigBlue's Avatar
BigBlue
Dad just got the Blackwing installed in his car this weekend. He loves it. The engine just wants to pull.
Old Mar 2, 2004 | 06:53 AM
Gramps's Avatar
Gramps
Not likely true.
Old Mar 2, 2004 | 09:36 AM
Automag928's Avatar
Automag928
Default Re: Blackwing Performance (Gramps)
Not likely true.
Well, I'd like to think the Donaldson filter element is a little better than stock. I'm sure it has better "filtering" ability than a stock paper element. Maybe I'm wrong, but I hope not.
As far as performance gains, you should get a few more HP, but you wont get 20 or 30 :).
Old Mar 2, 2004 | 12:45 PM
DAWS C5's Avatar
DAWS C5
Wonder if you opened the cowl under the BW for cold air and installed the cover too. Otherwise you're sucking warm air from the engine bay and I wouldn't expect a big increase.
:seeya
Old Mar 2, 2004 | 12:56 PM
CORTVET's Avatar
CORTVET
Default Re: Blackwing Performance (DAWS C5)
:seeya
I would not do that. I have read posts that say doing that causes surging in the car.
AZC5
Old Mar 2, 2004 | 01:26 PM
myblackC5's Avatar
myblackC5
g-techs are accurate and work good for the money, you just have to br exact on the weight of the car including the amount of gas.
:chevy
Old Mar 2, 2004 | 03:03 PM
TLKSCHP's Avatar
TLKSCHP
I installed a Blackwing with a cover and opended it up underneth with a little scoup. My best before with an a4 and 2.73s was 13.93 at 102 with a 60 ft of 2.14. After the install I ran a 13.59 at 105 with a 60 ft f 2.13. As far as the G-tech I used it at the track at the same time and it said I was running a 13.2 at 115. I can also break the tires loose now and couldn't before, plus hit a top speed of 170 MPH before I ran out of road. I feel it was the 1st thing anyone should do. For the record my 13.93 was with the zip tie mod and a stock filter.
Old Mar 2, 2004 | 03:53 PM
MrBill's Avatar
MrBill
Default Re: Blackwing Performance (myblackC5)
Gtech reports net horsepower and torque. It reports lower than a dyno because you're standing still on a dyno, you have actual drag in effect when the Gtech is measuring.
The Blackwing advertises a 15hp gain, that is maybe a .1 improvement in quarter mile times, probably too small to measure 0-60.
[Modified by MrBill, 8:54 PM 3/2/2004]
Old Mar 2, 2004 | 03:59 PM
AZGASSER's Avatar
AZGASSER
Default Re: Blackwing Performance (MrBill)
:iagree: The rolling resistance, drag, etc can be quite high. I is a good "yardstick" for trends. The Blackwing material by far exceeds OEM for filtering. This is the same media used on most millitary application in highly dusty/dirty situations.
To Blackwing Performance
Old Mar 2, 2004 | 06:39 PM
Rays Vet's Avatar
Rays Vet
Default Re: Blackwing Performance (AZGASSER)
The stock system is very restrictive and I too ran 13.9x stock but I put on the blackwing and a cooler t-stat and times dropped to 13.6x and I do'nt think the t- stat contributed that much.
Old Mar 2, 2004 | 08:29 PM
LBear's Avatar
LBear
Default Re: Blackwing Performance (Rays Vet)
If your looking for a true "ram-air" setup then Vararam is it. THe Blackwing is more of a cold air setup then a ram-air setup.
Old Mar 2, 2004 | 09:18 PM
02' vette's Avatar
02' vette
Default Re: Blackwing Performance (pettrix)
How are you guys running 13.6's and 13.9's with a 350-375 hp car???? I ran a 12.80 at 110 with an A4 with 3.15 ratio and CAI. My C4 with basically stock was running 13.30's-13.50's at 103-104. My car dynoed at 323 hp and 342 tq. Your time would suggest almost a 75-100 hp deficit unless your short times were like 2.3-2.5.
