LF air sensor
Old Mar 8, 2004 | 05:15 PM
98ISGR8's Avatar
98ISGR8
Default LF air sensor
Out of no where all of the sudden the front tire sensor comes up as zero pressure and I get the 55 mph warning on the dic. All the other tires read fine. Than after say 1 minute the LF sensor will register at 29 lbs and everything is ok. Could the battery in that sensor be going bad? Should I look somewhere else like the PCM or BCM.
Old Mar 8, 2004 | 08:36 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Default Re: LF air sensor (98ISGR8)
If those are the original sensors there is a good chance it could be going bad.
But before you run out to replace it try reprogramming it first.
Sometimes that's all it needs.
I don't think you need to look anywhere else.
Here's the procedure: https://www.corvetteforum.com/techti...D=77&TopicID=1
