best way to run wire
Old Mar 9, 2004 | 08:35 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Default best way to run wire
hooking up electric cutouts looking for the best way to run wires to center glove box?
thanks :crazy:
Old Mar 9, 2004 | 08:53 PM
NICK YOSKIN
St. Jude Donor '08
Default Re: best way to run wire (NICK YOSKIN)
anyone?
Old Mar 9, 2004 | 09:45 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Depending on exactly where your going to mount them. I'd run them up towards the passenger side firewall, if your an A4 follow the tranny cooler lines, then go through the main firewal gromment, passenger side lower floor, under carpet, and through front side on console.
That would be my method. I'd use heavy insulation to cover the wires/protection. For instance on my alt power wire (2 gauge cable) i ran the cable through a 5/8" id high pressure hose for added security. that would be over kill, but safer than sorry. :cheers:
Old Mar 10, 2004 | 03:08 PM
NICK YOSKIN
St. Jude Donor '08
Default Re: best way to run wire (JoeyG)
FOUND IT! emergency brake cable, perfect as it puts me close to console. :seeya
To best way to run wire
