DYNATECH SUPERMAXX INSTALL
Old Mar 10, 2004 | 09:52 PM
spiderman's Avatar
spiderman
Default DYNATECH SUPERMAXX INSTALL
Installed left hand side last week end. These are 1 3/4 tubes. The left hand side slipped in easier than what the instructions said to do. The instructions said I would have to remove some coil packs on the Left hand side, I didn't have to. The hardest thing so far was getting the last bolt out of the stock exhaust manifolds. Will be doing the Right hand side this coming week end. The O2 sensors were a breeze. This is on a 2000 C5 6-speed coupe. I am concerned about the clearance between the wiring harnesses etc. but will adjust them if possiable. The package and quality are top self. After complete will get an LS1 EDIT Tune . Will keep you posted on the progress.
Old Mar 11, 2004 | 06:36 AM
vettenuts's Avatar
vettenuts
Default Re: DYNATECH SUPERMAXX INSTALL (spiderman)
I am very interested in your progress, thanks for sharing. Also, two people who have installed to date had problems with the O2 sensors rubbing on the car tunnel. Would be curious if you run into the same situation.
Old Mar 11, 2004 | 07:38 AM
TopCat's Avatar
TopCat
Yeah, info on the sensors would be great.
Also, if you've got time before installing the second set, how 'bout some pics on the workmanship, especially the primaries where they connect to the head and the inside of the collector?
Additionally, I know these are long tubes, but if you get the chance, could you measure each primary for us and let us know how close to equal length they are? Enquiring minds want to know :cool:
:cheers:
Old Mar 11, 2004 | 09:13 AM
bgood's Avatar
bgood
Cruise-In IV Veteran
St. Jude Contributor
:thumbs: Going to have my set on soon. Enjoy :cheers:
Thanks for the install tip. Let us know how the other side goes.
Old Mar 11, 2004 | 09:18 AM
SideStep's Avatar
SideStep
Default Re: DYNATECH SUPERMAXX INSTALL (bgood)
bgood,
Keep me informed once you get yours installed... I am interested if you get P0133 and P0153 codes??? I am still having problems with these and my LTs :mad :mad :mad
Old Mar 11, 2004 | 09:30 AM
Mr. C's 5's Avatar
Mr. C's 5
Default Re: DYNATECH SUPERMAXX INSTALL (SideStep)
FYI; There is an article about these headers in the May issue of Corvette Fever. - C.
To DYNATECH SUPERMAXX INSTALL
