Been there done that, what do you need to know??
On a 01 you do not need the inst cluster, and its all plug and play.The hardest thing will be the wire harness (to find one) gm does not make one.Find someone that has a projector, bezel and harness.Cut the hole in the dash (there is a indent on where to cut under the pad) plug it in and your done.
