looking for feed back on the brake bias spring, they say it improves braking,and shorter stopping distance. is it worth adding on to the master cylinder? i have a 2000coupe
I do not know if the bias spring makes for shorter distances but it does reduce nosedive. I find it makes the transition from going straight to turning a bit easier. Since the rear brakes are doing more work than before it making it a bit easier on the fronts and they don't seem to over heat as much on a roadcourse or a fast run through the twisties as they did before.
Be sure to bleed the brakes when you install the spring or you might end up with the rears locking up and the ABS engaging too early.
Had some interesting videos of my 97 and a 99 at an autocross. We were both coming down a straight and hitting around 60 then hard braking for a hairpin turn. He had the spring I did not. As best we could tell his car nosed dived just as much as mine did.
Bill
ABS is computer controlled. The computer monitors the wheel speed sensors to detect wheel lockup. When the computer senses wheel lock up at one or more wheels it modulates brake pressure to the affected wheels to allow them to rotate a little. The only thing that will cause it to come on is wheel lock up as indicated by the sensors. So whatever contributes to wheel lock up will cause it come on. Improper bleeding can get air into the ABS modulation system and cause it to work improperly but cannot cause it to turn on. Only the computer can do that.
Bill
Thanks Bill, so it can make it not work but it won't make it kick in because that is controlled by the speed sensor / computer.
So to infer from wha you said Bill. The Bias spring gives you more rear brake. if you couple that with more pad you could get the rears to stop spinning at low speeds at which point ABS would kick in.
I replaced the bias spring by just removing and replacing the spring holder and didn't bleed (I know I should have) and my pedal feels great. Anyone see any problems.
I assume it got a little air, but didn't know how that spring compartment worked in the distribution block.
