Z06 Sway Bars
Old Mar 14, 2004 | 07:32 PM
DTV's Avatar
DTV
Default Z06 Sway Bars
I adding Z06 Sway Bars and saw Ecklers has a 30mm Z06 urethane bushing for the Front Bar. My question, is are bushing and holders diffent from the normal C-5 which is a frame bushing which is a little odd shape.
Old Mar 14, 2004 | 07:35 PM
allanlaw's Avatar
allanlaw
Default Re: Z06 Sway Bars (DTV)
The hole in the bushing is wider so you can get the thicker bar through it - is that your question?
Old Mar 14, 2004 | 07:46 PM
DTV's Avatar
DTV
Default Re: Z06 Sway Bars (allanlaw)
I wonder about the shape of the bushing. The picture of the 26mm bushing is one shape and the picture of the 30mm bushing is another shape or maybe Ecklers just has the wrong bushings
Old Mar 14, 2004 | 10:51 PM
Tsab's Avatar
Tsab
The bushing is the same shape just larger diameter to allow for the larger bar. I obtained mine from GMpartsdirect.com and it came with all the hardware necessary. Going to the Z06 bars is a good upgrade, you won't regret it.
Old Mar 20, 2004 | 06:13 PM
2KREDVert's Avatar
2KREDVert
Default Re: Z06 Sway Bars (Tsab)
Did you change your shocks too or just the bars?
Phil Swanson
Old Mar 20, 2004 | 08:44 PM
TheDarkKnight's Avatar
TheDarkKnight
Default Re: Z06 Sway Bars (philipswanson)
Well I did just the bars, and man am I loving it. :thumbs:
Old Mar 20, 2004 | 09:07 PM
DTV's Avatar
DTV
Just to give you guys an update. I got Poly Bushings from Eckler's. The rear bushings I had to drill out because they only had a 22mm and I needed a 23.6mm A 15/16 wood bit work great. I got rid of the plactic end links at the same time.
One old rear rubber bushing was stuck on the bar, so the bar could not move in the bushing also when I took the holder off the bushing came apart.
Result is the ride is just littler firmer, I like it. I tested the new setup last night and the car handle much better. Exit off I-95 ramp much much faster than before and it could had been puch more.
I do fell when it come time for new shocks the setup would be almost perfect for daily driving. :cheers:
Old Mar 20, 2004 | 11:31 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
:withstupid: :yesnod:
Old Mar 21, 2004 | 12:09 AM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Default Re: Z06 Sway Bars (Umrswimr)
:withstupid: :iagree:
To Z06 Sway Bars
