Smoking
Old Mar 20, 2004 | 09:35 PM
fsuforever's Avatar
fsuforever
Default Smoking
For some reason after i installed these patriot heads i have approx 2000 miles on these heads if that & it will only do this some times but the car when i crank it up it will smoke then it will go away like i said it will do this 5 out of the 10 times that i crank up the car, it just started doing this yesterday .I hear that its valve guides that are wore out is this correct ?I have seen other cars not vettes do this but now my 2k vette is doing this .Like i said its doing this only when i crank it up Can anyone chime in & tell me what this maybe
Old Mar 20, 2004 | 09:44 PM
joeking's Avatar
joeking
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Smoking (fsuforever)
Sounds like it may be valve guides or valve seals. I am no expert on the
C5 engine but if this is the case it is probably noticed more when the engine is cold?
Old Mar 20, 2004 | 10:08 PM
fsuforever's Avatar
fsuforever
Default Re: Smoking (joeking)
no it really doesnt matter if the motors cold or not it will smoke with the thermostat @ 160 or 180 it really ticks me off to know i spend 1700 dollars & not 2 months down the road & i have issues with these heads btw i am no expert to the c5 engine either but i had a friend of mine tell me that to him it was the guides .Lets see if some more people will chime in & give me there opinions of to what this maybe
[Modified by fsuforever, 3:09 AM 3/21/2004]
Old Mar 21, 2004 | 01:00 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I keep hearing MORE & MORE bad things about Patrorit Heads. THANK GOD that I never purchased heads from them!
BC
Old Mar 21, 2004 | 11:53 PM
denscor's Avatar
denscor
mine did that after a head change and the rocker arm bolts needed to a sealet on the threads and it went away.chack out on LS1tech and do a search the had a discussion on it.by the way my heads were LPE. that is what LPE told me also. :chevy
Old Mar 22, 2004 | 12:39 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
DENSCOR has a great suggestion! I recommend trying that first! It's a whole lot easier than a head removal!
BC :iagree: :iagree:
Old Mar 22, 2004 | 01:50 AM
dpd's Avatar
dpd
sounds like valve seals,if it were guides,you should smoke under high vacuum
situations[when throttle slams shut{on decel}].
i must say,it sounds like patriot has struck again.my suggstion would be to remove the heads and put your originals back on,before you end up with a broken valve spring or sucked valve[also a patriot trademark].call them,they may do you a solid and send you cylinder heads for a pinto!
Old Mar 22, 2004 | 03:34 AM
fsuforever's Avatar
fsuforever
Default Re: Smoking (dpd)
well i sold my stock heads so now i am stuck with these heads ,i will be calling them tommorow & letting them know that i have some bogus heads i just didnt want to have to tear down my motor again i just did this do u mean sealent like a threadlock sealent? i will try that it beats havimg to tear the motor down .Also when i drove the car today not the first sign of smoke .yesterday I could have killed all the bugs in baldwin county :lol:
[Modified by fsuforever, 6:16 AM 3/22/2004]
To Smoking
