Code 1416
Old Mar 22, 2004 | 08:58 AM
Doug9C1's Avatar
Doug9C1
Default Code 1416
I recently purchased 98 A4 Coupe with 58K miles. After a couple hundred mile cruise with the local club I picked up a Check Engine light. The code is 1416. I know it is an EGR sensor error. I haven't gotten the shop manuals yet and not sure what needs to be replaced. Anyone had this code and know the fix?
Doug
Old Mar 22, 2004 | 02:51 PM
Richin Chicago's Avatar
Richin Chicago
Default Re: Code 1416 (Doug9C1)
Doug
It means that air isn't making it to the exhaust manifold on the right side (passenger side) (air injection bank). Since the left side is working (air pump is operating), or you would also get P1415, I would guess that it is the check valve , or carbon build up where the tube goes into the exhaust manifold.
I haven't had to do this repair so maybe somebody else can give more hands on advice. If I remember correctly the check valve is a prime suspect as it is subject to corrosion.
[Modified by Richin Chicago, 1:53 PM 3/22/2004]
Old Mar 23, 2004 | 08:36 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Re: Code 1416 (Richin Chicago)
You have to remove the intake manifold, once it's out of the way you'll see the airtube and the check valve.
Old Mar 23, 2004 | 11:56 AM
Doug9C1's Avatar
Doug9C1
Thanks Guys!
To Code 1416
