Weight of Headers?
Old Apr 11, 2004 | 02:03 AM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Weight of Headers? (pdd000)
Sounds like good reasons to me! :cheers:
Old Apr 11, 2004 | 03:11 PM
JakeL's Avatar
JakeL
Default Re: Weight of Headers? (Blorton)
My 1 3/4" Kooks headers came out to being the same weight as the stock manifolds, ... These are all as weighed the day of install by me getting on the bathroom scale, getting off and picking up the parts, then subtracting the difference.
I weighed my set on a 50lb postal scale I bought for weighing parts:
Stock Manifolds: 12lbs x 2 (all the double walls were cracked and/or gone !!!)
H-Pipe: 44lbs
= 68lbs
Kooks Headers: 10lbs x2
Cats/X-Pipe/Intermediate Pipe: 29lbs
= 49lbs
FWIW, the cats weigh a TON on the Kooks system, so you could reduce that by at least 10 pounds if you were going with the catless system.
-Jake
Old Apr 11, 2004 | 05:20 PM
BQuicksilver
Default Re: Weight of Headers? (JakeL)
Huge Thanks JakeL! :cheers: :cool: :thumbs:
It looks like the list is complete.
Old Apr 20, 2004 | 05:36 PM
BQuicksilver
Default Re: Weight of Headers? (BQuicksilver)
Added Stainless Works to the list.
Old Apr 20, 2004 | 05:58 PM
vettenuts's Avatar
vettenuts
Has anyone weighed the Dynatech Supermaxx? Seems out of synch with the rest of the systems. Original theory was they had a cast collector, but that is not true.
Old Apr 20, 2004 | 06:00 PM
BQuicksilver
Default Re: Weight of Headers? (vettenuts)
I agree, that one does seem a bit off. Maybe some new owner will chime in. I think that weight came from z06vette.com
Old Oct 20, 2004 | 05:47 PM
vettenuts's Avatar
vettenuts
QTP are 50 lb shipping weight, installed weight may be lower especially because no clamps are used.
Old Oct 21, 2004 | 01:07 AM
BQuicksilver
Thanks, give me the final numbers once they're out of the packaging.
Old Nov 16, 2004 | 10:48 AM
Alex1217's Avatar
Alex1217
St. Jude Donor '08-'09
Wow, thanks for this great info. I've been trying to get an estimate of the weight savings I've achieved with my mods and this has really helped. For those of us with Pre-cats, how much do you think each one would weigh?
Old Nov 16, 2004 | 11:06 AM
BQuicksilver
That's tough to know, as I got my numbers from having people simply lay their systems on a scale.
I'm sure someone has a precat laying around that they can weigh.
Old Nov 16, 2004 | 11:09 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
From my FLP install page:
THE WEIGHT OF THE SYSTEMs:
STOCK 2000 coupe with pup cats,58lbs.
FLP W/CATS 61lbs.
DS header 12lbs,STOCK 9lbs. PS header 11lbs.,STOCK 10lbs. X-pipe 10lbs. X-pipe extension pipe w/O2 bungs 4lbs. Off road pipes 4lbs. Cats 20lbs. STOCK ASSY W/PUP CATS 37lbs Clamps/bolts etc. 4lbs.
Old Nov 16, 2004 | 08:10 PM
vettenuts's Avatar
vettenuts
Weight of QTP's can be found here in this forum thread:
QTP Header Weight
Note that I weighed these on a scale accurate to +/- 1 gram so the weight should be pretty good
Old Nov 17, 2004 | 01:20 AM
  #33
BQuicksilver
Thanks for the added info, unfortunately with the software change I cannot update the original post any longer.
Old Nov 17, 2004 | 01:22 AM
  #34
Ron Price's Avatar
Ron Price
While we all realize that lighter means quicker, could it be that the 13 or so lbs of the Dynatechs means that thicker gauge stainless is used? Maybe the flanges welded to the collector tubes that bolt them up to the heads is thicker? Could this possibly mean less prone to stress cracks or other problems? Maybe this is a question we should pose to Dynatech.
Old Nov 17, 2004 | 01:27 AM
  #35
BQuicksilver
I've wondered the same, but I don't think asking Dynatech is the best source, since they'll surely say the extra weight is just extra quality.
I think the best we can do is see if field reports of cracked LGM/QTP/Kooks come back more than Dynatech. Haven't heard of any of these cracking yet. Maybe the Dynatech's have a bit less "ticking" noise transmitted, as is a common complaint with others. Just thoughts.
It could also be that the others just did a better job with weight reduction.
Old Nov 18, 2004 | 01:22 AM
  #36
Ron Price's Avatar
Ron Price
I do know that the four clamps used by Dynatech are quite heavy and weigh something like one pound each. Not sure what the clamps on other systems with cats weigh.
Old Nov 18, 2004 | 07:12 PM
  #37
BQuicksilver
All 4 clamps together weight 2.5 lbs, I just weighed them.
To Weight of Headers?
Old Nov 18, 2004 | 08:12 PM
  #38
JBH's Avatar
JBH
My Dynatechs came last week. The shipping weight was 79 lbs. All of the packing material couldn't be more than 7-8 lbs.
Old Nov 18, 2004 | 08:16 PM
  #39
BQuicksilver
If there is any number I'm confident of, it's the Dynatech number. I'm sitting next to a set as I type.
Old Feb 23, 2017 | 11:02 PM
  #40
niterydr's Avatar
niterydr
I know I am bumping an old thread but I have a relevant contribution.
XS Power full C5 system with cats. (sold from Huron speed)
56.5 lbs (56lbs 8.2oz) Weighed just now. Thats the 1-7/8" primaries and 3" full exhaust and the cats, no bungs.
