Intermittent turn signal
Old Apr 1, 2004 | 06:12 PM
MattB_KY's Avatar
MattB_KY
Default Re: Intermittent turn signal (PVHolgado)
i have the same problem in my '99.......... cycling the hazard switch didn't help me any, guess i'll be forkin out the money for a turn signal switch........ may try the hazard first just because it's so cheap
Old Apr 2, 2004 | 12:01 AM
JYC5's Avatar
JYC5
Default Re: Intermittent turn signal (kyc5)
I have a 99 also with same problem. Replaced haz switch yesterday and works like a charm now. The blinker is actually in the haz switch. The dealer tried to tell me I needed to replace the entire turn signal switch in the steering column for mega bucks. What a crock.
Old Apr 11, 2004 | 06:25 PM
IrishFan's Avatar
IrishFan
Default Re: Intermittent turn signal (JYC5)
OK, after going three weeks without a single failure, I experienced 4 events today. Each time, I flicked the hazzard switch on and off and the problem went away. :crazy:
Dumb question #1: many states consider turn signals as a safety device. If there are so many vettes having this problem (as demonstrated by the small sample size in this forum), then why hasn't there been a recall?
Dumb question #2: how difficult is it to replace the hazzard switch? I'm concerned that a whole bunch of stuff needs to get removed to access the switch and, in the process of solving one problem, a whole new set of other problems are created.
Old Apr 11, 2004 | 06:56 PM
JYC5's Avatar
JYC5
Default Re: Intermittent turn signal (IrishFan)
Should take about 2 hrs to replace. Need to remove the dash & front panels to get to the switch. Switch $45 + time. I had mine in the shop for something else and had them replace it then. Again, they charged for 2 hrs of time. This did solve the problem. Good luck.
