Intermittent turn signal
Old Mar 24, 2004 | 09:47 PM
IrishFan's Avatar
IrishFan
Default Intermittent turn signal
The turn signal on my 2000 C5 has been a little flaky lately. About 20% of the time, the turn signal doesn't come on (either left or right signal) when I want to make a turn. Usually I just keep driving and the signals work fine at the next turn. Has anyone else had this problem? Any ideas what could be causing it? My first instinct was to replace the turn signal fuse...but I want to get some input before I go down that path.
Old Mar 24, 2004 | 09:50 PM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
Default Re: Intermittent turn signal (IrishFan)
I don't have an answer to your question but I did want to say welcome to the forum. :seeya
Old Mar 24, 2004 | 11:48 PM
EHS's Avatar
EHS
I have exactly the same problem. Happens on and off with no rhyme or reason. Goes away just as mysteriously. Both signals. Just plain dark and dead.
This was a hint from c4c5specialist: "It is most likely your emergency flasher switch."
Try this the next time it happens: push the emergency flasher switch in, then out.
Turn signals should work again. Let us know, for the "database" that this came out of.
You can replace the emergency flasher switch, but it's a couple of hundred dollars, according to the dealer.
:smash:
[Modified by EHS, 11:49 PM 3/24/2004]
Old Mar 25, 2004 | 01:37 AM
builtfspd2's Avatar
builtfspd2
do you have both brake lights working? i had the same problem. turned out to be the hazard switch ($40) and the turn signal switch ($235) and that doesnt include labor. solved the problem.
Old Mar 25, 2004 | 06:49 AM
pinot's Avatar
pinot
I have a similar issue but it is with my RH signal only. Previously it was erratic but now it is all the time. My rear lights are fine and I have changed the bulb up front.
Someone has the answer here. We have had several threads on this and there is nothing definitive yet. Given that the whole dash has to come out to RR the hazard switch I would like to know before we start just swapping parts and hoping. We need input from someone who has nailed diagnosing these things and then we can make it a Tech Tip so this issue goes away. Thanks all.
Old Mar 25, 2004 | 06:57 AM
steve1173's Avatar
steve1173
Default Re: Intermittent turn signal (pinot)
I have an 04 Z06, when it was one week old the r/f turn signal did not work & the system flashed fast. Parked in my garage tried it again same results, shut engine & left the car. Next morning it worked fine, no problem since in almost 3 months. Go figure.
Old Mar 25, 2004 | 07:43 AM
Fastbasser's Avatar
Fastbasser
Just had to replace my turn signal switch... Total.... Almost $400!!
:steering:
Old Mar 25, 2004 | 07:52 AM
EHS's Avatar
EHS
Well, pinot...
My input came as a result of a conversation with c4c5specialist, who has made a reputation and living nailing and diagnosing these things.
The specific symptons listed by IrishFan were:
1. Intermittent (20%)
2. Both signals
3. Return to normal operation without intervention
Both builtfspd2 and I pointed to the emergency flasher switch. I have verified this, so has builtfspd2. So has c4c5specialist.
For me, that's pretty "definitive," especially since I've now used that solution about five or six times in the last five or six months, and it works every single time. Instantly.
You're input on the cost of replacing the switch confirmed the quote from the dealership. Pushing the flasher switch in and out the next time this occurs is a free diagnosis and fix for IrishFan. It could also be one for you, although you're symptons are somewhat different, e.g., one signal only, and all the time. Let us know when you've tried it.
Cheers. :cheers:
Old Mar 25, 2004 | 09:48 AM
Bluevette2000's Avatar
Bluevette2000
I had the same problem with my 2000. It is the hazard switch which causes this problem, $35.00 from the dealer or cheaper online.
I removed the kick plates below the steering column so I could reach my hand up to the hazard switch. I also had my radio out because I was replacing the A/C display.
I then removed the cover on the hazard switch, the one with the orange triangle by prying it off carefully. The hazard switch has two tabs that hold it in place. I first tried to lift both at the same time but there is very little room. So I put a flat blade screwdriver on the front of the old unit and hit the back with the palm of my hand. It popped out the first hit and I snaked the unit and wires down. Took less than an hour total time and everthing works fine.
Old Mar 25, 2004 | 10:12 AM
NV MY C5's Avatar
NV MY C5
Senior Member
Cruise-In V Veteran
Default Re: Intermittent turn signal (Bluevette2000)
Ive had the same problem. Its definatly not the fuse. I am suspecting the turn signal switch as well.
Old Mar 25, 2004 | 04:57 PM
Mel 2001's Avatar
Mel 2001
Intermttent turn signal: Had my hazzard switch replaced under exteneded warranty. :D
Old Mar 25, 2004 | 05:00 PM
simplyred02's Avatar
simplyred02
Default Re: Intermittent turn signal (Mel 2001)
in about 80% of c5's it's the turn signal flasher
Old Mar 25, 2004 | 06:18 PM
EHS's Avatar
EHS
Default Re: Intermittent turn signal (simplyred02)
Sorry to disagree.
In about 80% of the C5s, it's the emergency (hazard) switch.
Not that the above posts are a statistical sample, but that's the case. :smash:
Old Mar 25, 2004 | 07:15 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Default Re: Intermittent turn signal (EHS)
Sorry to disagree.
:iagree: Absolutely.. Hazard switch.. I made the mistake of screwing with mine (gee, I mean pushing it in and out as designed) when I noticed my turn signals were intermittent, and now it seems to have made it worse.. Now I end up cycling the hazard switch to get the turn signals going about 50% of the time! :crazy:
[Modified by Dan_the_C5_Man, 7:16 PM 3/25/2004]
Old Mar 25, 2004 | 10:03 PM
IrishFan's Avatar
IrishFan
Default Re: Intermittent turn signal (Dan_the_C5_Man)
Thanks for all the input; you guys rock!
I'll give the hazard switch a try next time this happens and will report back on my findings.
Old Mar 25, 2004 | 10:27 PM
RedHot's Avatar
RedHot
CI 5-6-7-8-9-10 Vet
I had the same problem and this what fixed it. It is not a minor repair as they have to remove the console and dash to get to the flasher module.
Old Mar 26, 2004 | 08:13 PM
Sorny's Avatar
Sorny
Definitely your hazard switch. My car had that behavior immediately after I purchased it. My extended warranty wasn't in effect yet, but the dealer replaced it no cost because it was a safety issue (and was within 10 days of purchase, when I got my '00 back in Feb.).
Sorny
To Intermittent turn signal
Old Mar 30, 2004 | 10:33 PM
IrishFan's Avatar
IrishFan
Default Re: Intermittent turn signal (Sorny)
Well, I'm pretty frustrtated. :cuss
I drove around the city for 60 miles this weekend and not a single event; the turn signal worked every single time. Grrrrr...
I'll give it another try next weekend...
Old Mar 31, 2004 | 11:14 PM
Mel 2001's Avatar
Mel 2001
Mine would not work maybe 2-3 times a month. No problem after hazzard switch replaced. :auto:
Old Apr 1, 2004 | 02:55 PM
PVHolgado's Avatar
PVHolgado
Had both turn signal and hazard switch replaced on my 2000 FRC under warranty at 35,400 miles-- I think their is a TSB out on this- You might check with dealer.
