Heat Socks
Apr 7, 2004 | 07:23 PM
Heat Socks
Have any of you used the heat socks on the plugs when you did a header install. And if you did, where did you purchase them from and at what cost?
Apr 7, 2004 | 09:01 PM
Re: Heat Socks (TomsZ06)
Apr 7, 2004 | 09:20 PM
Save and use the stock heat shields that come with the car - they work fine.
Apr 9, 2004 | 11:40 AM
I have the "socks" and they work fine. Got mine at a local hot rod store. :)
Apr 9, 2004 | 11:47 AM
St. Jude Donor '11-'12-'13, '15
Re: Heat Socks (Bob Chapman)
Yes but they won't work with all aftermarket cables, Taylor Thundervolt 50's for sure and perhaps some others.
Apr 9, 2004 | 12:02 PM
Re: Heat Socks (sweetcharity)
on my LG install, I found the stock shields work fine,, but I had heat socks and they look better, so I thought about double up and one plug was so close you cant get both to the sock and metal shield to clear the header...so I went with socks....if I didnt have them, stock would have been fine, infact maybe even better
Apr 9, 2004 | 01:49 PM
Re: Heat Socks (wrustywrench)
i used the stock wires and heat shields.
Apr 9, 2004 | 01:53 PM
Re: Heat Socks (Ryan2002C5)
check out LAPD. i installed these last weekend with my lg's. definitely worth it as #2 rests right on the header.
http://www.thelapd.com/Merchant2/mer...egory_Code=ptc
Apr 9, 2004 | 02:32 PM
Re: Heat Socks (rutiger)
Have em , like em , not really necesary but I like the extra protection.
40 bucks got either MAM or WCC cant remember where :cheers:
Apr 9, 2004 | 03:35 PM
got my socks from ecklers.they were like $45.
