can the speed sensor in diff be removed w/o dropping diff or subframe?
Old Apr 12, 2004 | 05:36 PM
T_Vert's Avatar
T_Vert
Default can the speed sensor in diff be removed w/o dropping diff or subframe?
I just want to know in case my VSS is bad in my diff.
Dave
Old Apr 12, 2004 | 08:36 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: can the speed sensor in diff be removed w/o dropping diff or subframe? (TT_Vert)
the sensor is on top of the diff case. It would be tough since you might not be able to see what your hands are trying to do.
In this pic, the round black housing on top is the VSS (and you will also see Mike Norris - known as "The Man" ) :thumbs:
another pic (lower right corner):
[Modified by Mike Mercury, 8:39 PM 4/12/2004]
Old Apr 12, 2004 | 09:04 PM
T_Vert's Avatar
T_Vert
Default Re: can the speed sensor in diff be removed w/o dropping diff or subframe? (Mike Mercury)
i know where it is. Its just that the diff i put in had a questionable VSS. Im just wondering if there is enough clearance to get it out w/ the diff in the car
Dave
Old Apr 12, 2004 | 10:09 PM
Mike Mercury
i know where it is.
well good for you. :rolleyes: Sorry I wasted your time looking up all those pics .
[Modified by Mike Mercury, 10:11 PM 4/12/2004]
Old Apr 12, 2004 | 11:19 PM
T_Vert's Avatar
T_Vert
thanks for your time, i just need to know if its possible to get it out w/o dropping the cradle down. Like i said, i put a diff in today but the VSS is questionable but i didnt really wanna swap it out w/o trying it first. Hence my question.
Dave
Old Apr 12, 2004 | 11:48 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
MIKE
You DID NOT waste your time! I learned something, and so did anyone else that looked at this post and never had the opportunity to rip out the rear end! :thumbs: :thumbs:
THANK YOU for posting it.
BC
To can the speed sensor in diff be removed w/o dropping diff or subframe?
