Question about changing brake rotors
Old Apr 22, 2004 | 08:57 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default Re: Question about changing brake rotors (NickL1)
Same bolts from 1999 and the rotors have come and gone in less than three days from road racing. Just what I have done forty or fifty times at the very least.
Old Apr 22, 2004 | 09:04 PM
vettenuts's Avatar
vettenuts
Default Re: Question about changing brake rotors (John Shiels)
No need to change washers. If you get the extra bolts, you can always have a cleaned and prepped set if you intend to do a lot of change overs.
Old Apr 23, 2004 | 12:21 AM
Black99Corvette's Avatar
Black99Corvette
Default Re: Question about changing brake rotors (Slickk.)
I've reused the bolts many , many times w/o locktite and haven't had them come loose even once.
:iagree:
Just use the factory torque specs
Old Apr 24, 2004 | 02:25 PM
NickL1's Avatar
NickL1
Does anybody know if I need a normal(short?) 21mm socket or a deep well socket for removing the caliper brakets?
Old Apr 24, 2004 | 02:31 PM
Richin Chicago's Avatar
Richin Chicago
You don't need real deep. In fact it will work against you if you really have to apply a lot of torque.
