Question about changing brake rotors
Old Apr 14, 2004 | 02:02 PM
NickL1's Avatar
NickL1
Default Question about changing brake rotors
I'm looking at using a set of dedicated rotors/pads for track days. I've read on the forum that the Caliper bracket bolts can only be used once. The only way to get the rotors off is to remove the caliper brackets.
So every time the rotors are changed are all these $5 bolts really just thrown away? Seems expensive if the rotors are changed many times per season.
Or are people reusing them?
Old Apr 14, 2004 | 02:03 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Default Re: Question about changing brake rotors (NickL1)
:lurk: :lurk:
Old Apr 14, 2004 | 02:14 PM
dmtnt's Avatar
dmtnt
St. Jude Donor '03-'05-'06 & '12
Other may disagree, but I just put red loctite on them. Have reused mine twice with no problems at all. :)
Old Apr 14, 2004 | 02:47 PM
Jim D's Avatar
Jim D
:iagree:
Old Apr 14, 2004 | 02:48 PM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
Default Re: Question about changing brake rotors (dmtnt)
:iagree:
Old Apr 14, 2004 | 02:58 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
I re-used mine also; a no-no, yes, but did it anyway..
[Modified by Dan_the_C5_Man, 6:51 PM 4/14/2004]
Old Apr 17, 2004 | 05:27 PM
vettenuts's Avatar
vettenuts
Default Re: Question about changing brake rotors (Dan_the_C5_Man)
Only reason to change it for the Loctite. You may want a second set so you can have one cleaned and ready to go, just use Loctite 271. It's the only red I can find.
Old Apr 17, 2004 | 05:36 PM
Slickk.'s Avatar
Slickk.
Default Re: Question about changing brake rotors (vettenuts)
I've reused the bolts many , many times w/o locktite and haven't had them come loose even once.
Old Apr 17, 2004 | 11:15 PM
George8211's Avatar
George8211
Default Re: Question about changing brake rotors (Slickk.)
Interesting.... I never heard of replacing the bolts :crazy:
Old Apr 18, 2004 | 02:04 AM
DUCMAN's Avatar
DUCMAN
Default Re: Question about changing brake rotors (George8211)
:withstupid:
Cahnged my rotors and did not even think about the bolt issue
Old Apr 18, 2004 | 03:30 PM
vettenuts's Avatar
vettenuts
Default Re: Question about changing brake rotors (DUCMAN)
By the way, if you do change them I just purchased a set of eight for under $35 shipped from Fred Beans, one of the forum vendors.
Old Apr 18, 2004 | 10:39 PM
corvettefrance's Avatar
corvettefrance
I did not know either. I bolted them back w/o loctite.
I may check them next week-end.
Old Apr 19, 2004 | 12:10 PM
Dan_the_C5_Man
Just an FYI, the factory manual specifically states:
These fasteners MUST be replaced with new fasteners anytime they become loose or are removed. Failure to replace these fasteners after they become loose or removed may cause loss of vehicle control and personally injury.
You have been warned; now go live dangerously! :jester
Old Apr 19, 2004 | 07:41 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
I reuse them; have for years. However, I always clean the old thread locker off the bolts with a wire brush, then I run a tap down the bracket threads to clean out the thread locker in the threads. Then, I apply Loctite, and make sure to torque to 175 N.m.
Yes, GM states to reuse...why, maybe, and this is a maybe, they feel that most people will not take the time to clean the bolts and the internal threads of the bracket. Again, maybe...me not say for sure. However, I will bet very few technicians change the bolts.
Old Apr 20, 2004 | 06:03 AM
vettenuts's Avatar
vettenuts
Default Re: Question about changing brake rotors (WhiteC5Vette)
Just as an aside, the list price for the bolts is around $8.50 each or $68 for a set of eight. I think a lot of people would be screaming if they were charged that when rotors were changed. The mark-up is incredible and they can be had for a lot less from the forum vendors.
Old Apr 20, 2004 | 07:20 AM
Richin Chicago's Avatar
Richin Chicago
GM# 14084051 Large Caliper Bracket Bolt 21 MM head
8 of them cost $34.03 delivered from:
http://www.gmpartsdirect.com
Old Apr 20, 2004 | 02:58 PM
NickL1's Avatar
NickL1
Anybody know if the caliper mounting bolts(14084051) are the same for the front and rear caliper brackets?
To Question about changing brake rotors
Old Apr 20, 2004 | 03:10 PM
Richin Chicago
Thet are the same for all 4 calipers brackets.
Old Apr 22, 2004 | 08:18 PM
NickL1's Avatar
NickL1
Thanks for all the help so far. Still debating on whether to order a new set of bolts. I know the part number for the bolt is 14084051. Does anybody know if its recommended to replace the washers as well? Any idea what the part number is for those?
Old Apr 22, 2004 | 08:46 PM
Richin Chicago
In my opinion there is no need to rplace the washers. They are not a crush design nor are they part of the sealing.
