Removing stock air filter setup?
Old Apr 14, 2004 | 07:01 PM
TrackAttack!'s Avatar
TrackAttack!
St. Jude Contributor
Default Removing stock air filter setup?
I am getting ready to install the Halltech Stinger R in place of the stock setup. Does anyone have any good directions on removing the stock equipment? The part I am most interested in is how to remove the stock air filter box. Looks like there are two mounts located in the bottom of it that need to come out to remove it.
Thanks!
Joe
Old Apr 14, 2004 | 09:58 PM
TrackAttack!
Default Re: Removing stock air filter setup? (TrackAttack!)
Figured it out. Take out the two torx screws and the box comes out! Got the Stinger R installed! Have not started it or taken it out yet, but will this weekend. :steering:
MidLifeinMI's Avatar
MidLifeinMI
From: MidLifeinIL just doesn't have the same ring to it
St. Jude Donor '26
The stock box has 2 rubber grommets that are mounted over posts in the front end of the car. They're not the easiest thing, but they will pop off, if you do them one at a time. A little leverage helps. :cheers:
Old Apr 14, 2004 | 10:44 PM
Dave68's Avatar
Dave68
Saaaaay, how did you receive yours so fast?! I'm expecting mine any day now and will hopefully have it installed this weekend. :cheers:
To Removing stock air filter setup?
