Stinger Intake System
Old Apr 19, 2004 | 08:20 PM
TomsZ06's Avatar
TomsZ06
Default Stinger Intake System
Does this filter need to be oiled before using? The filter is blue in color.
Old Apr 19, 2004 | 08:30 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Default Re: Stinger Intake System (TomsZ06)
Comes pre-oiled and is good for 15,000 miles between cleanings.
Jim Hall
Old Apr 19, 2004 | 11:13 PM
Sixgun95's Avatar
Sixgun95
Jim, Is the pre oil for 15K true on the Syn Remay also?
Old Apr 20, 2004 | 03:04 AM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Default Re: Stinger Intake System (Sixgun95)
Yes, both filter media.
Old Apr 20, 2004 | 11:55 AM
Sixgun95's Avatar
Sixgun95
Default Re: Stinger Intake System (Jim Hall)
Jim, Has mine been shipped yet, if so when? Tracking number please?
Thanks!
ORDER NUMBER: 480
ORDER DATE: 14-Apr-2004:14:45
[Modified by Sixgun95, 10:56 AM 4/20/2004]
Old Apr 20, 2004 | 12:52 PM
jcbob's Avatar
jcbob
Cruise-In II Veteran
Thanks!
ORDER NUMBER: 480
:iagree:
Order Number: 467
Order Time: 13 April 2004 11:54AM
:lurk:
Old Apr 20, 2004 | 01:24 PM
Demented's Avatar
Demented
Default Re: Stinger Intake System (jcbob)
They send you a noticifcation in your e-mail from UPS. The mail is from QuantumViewNotify@ups.com
<--Scheduled Delivery: 20-April-2004
That's today!:)
P.S. I was order 457
[Modified by Demented, 12:28 PM 4/20/2004]
Old Apr 20, 2004 | 02:58 PM
hot4u's Avatar
hot4u
Same question here order # 479 haven't heard anything yet
Old Apr 20, 2004 | 03:34 PM
Sixgun95's Avatar
Sixgun95
Just got off the phone with Jim...excellent customer service! It is greatly appreciated sir! :hurray: :hurray:
After further review, I take back the above statement. :boxing
[Modified by Sixgun95, 4:47 PM 4/22/2004]
Old Apr 20, 2004 | 07:17 PM
Ebein's Avatar
Ebein
Im 459 and mine should arrive tommorrow according to UPS.
Old Apr 20, 2004 | 08:31 PM
TrackAttack!'s Avatar
TrackAttack!
St. Jude Contributor
Takes about a week to get it. Ordered mine on a Sunday and got it on the following Friday. :)
Old Apr 20, 2004 | 08:50 PM
Demented's Avatar
Demented
Default Re: Stinger Intake System (TrackAttack!)
I just installed mine..here's a few tips brought to you by bloody knuckles and lots of curse words. You can't put the filter on the MAF until after you have the bridge hooked up to the throttle body. There isn't enough room until the bridge is seated and in place. Everything is extremely tight..use some WD-40. Also the MAF side that sticks out needs to be pointed sideways or down...not up. 5-minute install time is a bit optimistic heh. P.S. how do you get the rubber sealer ring from the little air tube to go into the filter hole? I pressed and pressed and lubed and lubed(nasty minded people!) and I couldn't get it in. I ended up taking it off and not bothering with the rubber sealer.
Old Apr 20, 2004 | 10:05 PM
TeamSpeed's Avatar
TeamSpeed
Default Re: Stinger Intake System (Demented)
The directions state to leave the rubber grommet in the stock air box, it is not needed.
I had a heck of a time getting the silicon coupler to the throttle body. I ended up stretching it by pushing the entire coupler over the end of the plastic tube, then taking it off and fitting it on the throttle body after it was stretched/loosened a bit.
Now I have to make sure that I have the placement correct so that my hood is not bulging up at the front.
Old Apr 20, 2004 | 10:25 PM
Dave68's Avatar
Dave68
Default Re: Stinger Intake System (TeamSpeed)
If anyone would like detailed (with plenty of pics) instructions, just let me know. I creatd a Word document that goes into more detail than Jim's quick-instructions. I've been trying to upload the pics so I could post the instructions here, but due to a problem with this forum, it's no-can-do. However, I'll try often and if the upload feature is fixed, I will post instructions and pics.
Old Apr 20, 2004 | 11:01 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Default Re: Stinger Intake System (Dave68)
Email it to me at info@CorvetteC5.com and I'll post it.
All remaining orders should ship this week, except the 97-2000 units. We ran out of filters, but should have a new order the end of next week.
Jim
Old Apr 20, 2004 | 11:48 PM
Dave68's Avatar
Dave68
It did take a bit of work to get this on, but believe me, you're far better off with a tight fit and NO air leaks. I've had many years of experience working with pneumatic hose and couplers, so I know the technique very well. There is a product that is perfect for helping out in situations like this. That products is called P-80. It is a temporary lubricant that evaporates after assembly. It acts like silicone but disappears and leaves little or no residue. You can even use the stuff to lubricate taps; it comes in thin and thick formulas. Here's the website:
http://www.ipcol.com/prod-p80.htm
Jim, I sent you the word document.
Everyone else: You will love this system. It fits so well that no hold-downs are necessary - very impressive engineering! :thumbs:
[Modified by Dave68, 8:54 PM 4/20/2004]
Old Apr 21, 2004 | 12:15 AM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
We actually had the coupler made undersize to avoid leaks. it is very easy to install, but you must leave the hose clamps off until the end.
We use Windex on the rubber F-Seal receiver for the plastic end of the MAF, it is pretty slippery and allows insertion of the MAF easily. Otherwise it will not go in.
Jim
Thanks for the info.
Jim
[Modified by Jim Hall, 9:18 PM 4/20/2004]
To Stinger Intake System
Demented's Avatar
Demented
Hah Directions? I think Jim musta been real busy when he sent mine..all I got was a 25 dollar coupon and a business card heh. I had to do it the old fashion manly way. Trial and Error:)
Old Apr 21, 2004 | 12:28 AM
TeamSpeed's Avatar
TeamSpeed
There was a PDF under the installations link on the Halltech site talking about the Stinger installation... :cheers:
Old Apr 21, 2004 | 10:16 AM
Dave68's Avatar
Dave68
Jim also posted the instructions in this forum section shortly after introducing the Stinger system.
