Active Handling problem, How to correct or disconnect!!
Old Apr 28, 2004 | 04:01 PM
brad911sc's Avatar
brad911sc
1st Gear
Default Active Handling problem, How to correct or disconnect!!
I have a 1999 Hardtop 6spd. Active handling, grabs front right wheel only, slow speeds or turning for no reason, it has cost me lots of $$$ to replace what the codes come up with but still not fixed! Can shut off at push button but then light on dash stays on! (annoying) and bells and whistles go off periodically to have the system checked! Question Can I just unplug it at console or swap wires to shut off when I start the car plus the dash light. their are six wires that go into the on off switch! need Help & solution!! e-mail me at bcb9112001@msn.com I just hit the off switch every time I get in Now!! :
Old Apr 28, 2004 | 04:07 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Active Handling problem, How to correct or disconnect!! (brad911sc)
You can have a dealership or someone who has access to a GM Tech 2 disable AH/TCS via RPO reprogramming.
