HELP!!!!!! - ROTORS
Old Apr 30, 2004 | 10:17 AM
Lancer033's Avatar
Lancer033
Default HELP!!!!!! - ROTORS
My car is on jack stands, I'm working on changing the rear rotors.
The calipers are off
The parking break is disconnected
The 2 retaining clips are gone and this sucker ain't moving at all
The service manual says to rotate it while pulling on it :bs nothing happened
Then I tried a rubber mallet ...... nothing happened.
What did I miss :confused: :confused:
Old Apr 30, 2004 | 10:33 AM
Bill Reid's Avatar
Bill Reid
Default Re: HELP!!!!!! - ROTORS (Lancer033)
On occasion we'll see rotor's "glued" in place by rust. Try a little penetrating oil around the hub area and hit the rotor again with a wooden or rubber mallet. The rotation motion while pulling on the rotor is to help prevent the e-brake shoes from catching and being pulled apart while removing the rotor.
Bill :)
Old Apr 30, 2004 | 10:52 AM
Richin Chicago's Avatar
Richin Chicago
Default Re: HELP!!!!!! - ROTORS (Bill Reid)
Bill :)
I agree
Some of these rotors only respect violence. A piece of wood or a non metalic hammer and some anger is what is needed! Also make sure your emergency cable isn't tight.
Old Apr 30, 2004 | 11:29 AM
Lancer033's Avatar
Lancer033
Never mind, I gave Aaron at StopFORCE a call and based on his recomendation, i soaked the (*&$ thing inWD40----Then hit it a few more times with the mallet.
:cheers:
Old Apr 30, 2004 | 11:33 AM
Lancer033's Avatar
Lancer033
Default Re: HELP!!!!!! - ROTORS (Richin Chicago)
I agree
It almost came to that. Thanks for the advice, i've got to get off the internet and get back to work
Old Apr 30, 2004 | 02:58 PM
ragtopws6's Avatar
ragtopws6
Try a big hammer, if that doesn't work get a bigger hammer, if that doesn't work.......well you know. :D
Old Apr 30, 2004 | 04:43 PM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
WD-40 & a BFH!!!!!!!!! :smash: :smash:
Old Apr 30, 2004 | 04:48 PM
GR8-LIFE's Avatar
GR8-LIFE
Bill :)
I agree
Sounds like you got the Middle East batch :lol:
Old May 1, 2004 | 12:51 AM
Lancer033's Avatar
Lancer033
Default Re: HELP!!!!!! - ROTORS (MARK's_C5TT)
Bill :)
I agree
:lol: :lol: yep
To HELP!!!!!! - ROTORS
