Help! I got the codes, now what?
P1571- ASR Desired Torque
P1626- Theft Deterrent System Fuel Enable Circuit
P1644- Delivered Torque Output Circuit
My question is what do these codes mean and how do I go about fixing them? Any input is greatly appreciated.
:cheers:
1626 - disconnect battery positive cable for 1 minute. Will car start or start and die? If still idles check body control systems. PCM, BCM and ignition lock and key are part of this system.
1644 - not listed on my manual.
Both codes indicate much electrical probing and scan tools.
Reading between the line I'd look at the PCM under the battery. Ever have a leaking battery in your Vette?
IMHO, if you do not find a loose wire/ connector either you'll need a manual and time to diagnose yourself or send to dealer.
Thanks again. :seeya
