HELP With Codes
Old May 13, 2004 | 09:46 AM
mgora1's Avatar
mgora1
Default HELP With Codes
I just installed headers and high flow cats. The installer did LS edit tweaks but I am getting a P0141 and P0161, as well as the check engine light. I have reset the codes but they come back after a few minutes. Is there a concern with driving the car before I can get someone to look at?
Old May 13, 2004 | 11:14 AM
bgood's Avatar
bgood
Cruise-In IV Veteran
St. Jude Contributor
Default Re: HELP With Codes (mgora1)
Are you getting any other codes? What appears to be happening is that the rear O2 sensors are not heating enough. How far back are the rear O2's located? Do you have rear O2 sims since the header install or are you still using the rear O2's?
Old May 13, 2004 | 11:45 AM
mgora1's Avatar
mgora1
Not getting any additional codes. I think they left the original O2 sensors. I have already left a message for the shop that did the work. The car is running great.
To HELP With Codes
