When giving tech advice:
Old May 19, 2004 | 11:07 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: When giving tech advice: (Heretic)
My favorite internet car related myth. Less backpressure ="less torque"
My favorite WAS " The LS1 doesn't like big cams. It's different than a SBC".
I posted 1 1/2 years ago about the Grand Am cam. Repeatedly, I was told this. In fact some respected tuners stated that it wouldn't be a good " Power" cam. Pure internet myth. My .02.
:D
Old May 20, 2004 | 04:24 AM
66ImpalaLT1's Avatar
66ImpalaLT1
Default Re: When giving tech advice: (Dave68)
Someone asks how fast a 2001 coupe is in 0-60 MPH. How many of us have the $10,000 instrument that Car & Driver and other car mags have to actually find out?
I've tested my car with a Stalker ATS, they dont cost $10,000 and can be rented. I'm sure I am not the only one. Along these same lines I'm really sick of people quoting 0-60 times derived from 60ft times, thats pure BS.
Old May 20, 2004 | 09:37 AM
SpinMonster's Avatar
SpinMonster
Default Re: When giving tech advice: (Richin Chicago)
Your car won't break in with synthetic oil.
It's cheap insurance to channge oil every 3000 miles.
I have yet to use synthetic on any of my cars. the only advantage is if you use if over 3k miles anyway. My goodness how does my 426 hemi run without it. 55-65 bucks for an oil change and that was the last time I used it.
I do change oil often. I guess I dont't care how much $$$ gm gets to market the oil.
My favorite myth has to be the 4.10 gears issues:
The car will not be driveable on the hiway (high RPM)
The wheels will spin too much if you go to 4.10's: Gearing a car with 4.10's helps traction by slowing down the number of tire revolutions per engine rpm. While the fact is that you will break loose more often, the distance you travel will be shorter until you hook. I have 6.13's in my dart.
Mileage will suffer too.....I get 25 with the 4.10's.
I have never seen one anti-gearing post by anyone who geared.
Old May 20, 2004 | 09:38 PM
Sandra Bigwoode's Avatar
Sandra Bigwoode
Default Re: When giving tech advice: (SpinMonster)
C'mon we all know these guys
1-aluminum flywheels cause harder launches
2-You get KR with compression over 11:1
3-heads dont give you much power increase
4-Gears over 373 are bad for hiway driving
5-East Coast: LG headers suck
6-West coast: Kooks headers suck
7-Ohio: FLP's rule
the myths just never stop
[b]well there, pilgrim, how about dese guys:
1. the c5 is very well balanced bone stock from the factory and you really have do your homework to improve on it using only bolt-on 'performance' parts.
2. 117 octane xylene mixed 30%-70% with 93 octane gives you 100 octane.
3. 160 f. tstats lower your engine's thermal efficiency, not raise it, thereby costing you power.
4. drilling holes in your disc rotors reduces their mass, makes them less effective in absorbing heat braking energy and makes them liable to crack along the holes. but what the hay, they look real kewl...
5. installing aftermarket exhausts and pipes for many hundreds of $ will enable you to make lots of noise, look real cool but not make any real measurable torque or hp.
6. lowering your c5 more than 1 inch will result in more scraping on driveways, and you should get shorter shocks if you go below 1".
7. changing your mobil1 synthetic oil every 3,000 miles is a waste of money, use the dic 'oil remaining' values instead.
8. running a supercharger above 6 1/2 #'s boost on a stock ls6 engine is not a good idea.
Old May 20, 2004 | 10:07 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: When giving tech advice: (Sandra Bigwoode)
my fav:
rear axle change in a C5 will throw your speedo off.
Old May 21, 2004 | 12:20 AM
Midwayman's Avatar
Midwayman
Errrrr.... maybe if you're on the street this doesnt matter, but this statement actually is true.
Old May 21, 2004 | 04:46 PM
SpinMonster
Default Re: When giving tech advice: (Mike Mercury)
my fav:
SHHHH, hey Mike I think for the automatics it does!!
Anyway I got an IM about 4.10's today. Nice guy and he said that he was told.....ding ding ding......that they lower your top speed.
Well guys I personally went 180 in 6TH GEAR (4750rpm) and it was still climbing. I had the headlights up and a passenger. I have a feeling that with cold air, new PIAA's and no passenger, it will hit very close to 200.
4.10's put the motor into the power band again and let you use 6th as the top speed gear. NEPTUNEBILL did 195 or so with 3.90's (and like my run, it wasnt the limit). Lingenfelter said on his site that 450rwhp and 4.10's were all that was nec. for 200mph with all else working for you. Best I did in 5th gear was 177 with 3.42's which was the vehicle limit and not at the redline.
Old May 21, 2004 | 04:57 PM
Richin Chicago's Avatar
Richin Chicago
my fav:
A fairly simple program I have says for the frontal area and CD of a C5 you need around 560 HP to do 200 MPH.
Old May 21, 2004 | 05:35 PM
George8211's Avatar
George8211
7-Ohio: FLP's rule
C5 rotors warp easily.
Changing stock plug wires, even if they are in good shape, will give you more horsepower.
Cross drilled rotors give you better braking performance.
This $400.00 intake will give you xx more horsepower. I can tell by the feel.
Zaino lasts longer than anything else.
Are you telling that all this stuff is not true :confused: :lol: :lolg:
Old May 21, 2004 | 05:53 PM
Richin Chicago
Default Re: When giving tech advice: (George8211)
7-Ohio: FLP's rule
Beauty is in the mind of the beholder...
Old May 21, 2004 | 06:14 PM
Mike Mercury
Richin; if that's the false info we want to tell these people; then I'm game. :) Just make sure I get the memo ahead of time so I can play along.
Old May 21, 2004 | 10:58 PM
Sandra Bigwoode
[b]yowsah, please post a link!
iirc and the lingenfelter site seems to be down right now, but they needed 500+ rwhp to pull 200 mph, the c4 and c5 are drag limited on top speed regardless of gearing and tire sizes...
Old May 21, 2004 | 11:14 PM
  #33
Richin Chicago
Just an extrapolation.
It assumes a 345 HP corvette tops out at 170 and then uses the formula ((A3/A1)^3)*C1 Where A3 is the desired speed and A1 is 170 MPH and C1 is 345 HP. It assumes you have to increase the horsepower by a factor of 8x (cubed) to increase the speed 2x Aerodynamic drag is a real b*tch!
Old May 21, 2004 | 11:25 PM
  #34
George8211's Avatar
George8211
OK... makes sence to me....
lingenfelter site ... but they needed 500+ rwhp to pull 200 mph
Gee... last time I check 560 hp was in the catogory of 500+ hp
:smash:
Old May 21, 2004 | 11:46 PM
  #35
66ImpalaLT1
Wow, this thread has turned into a typical C5 Tech thread. People posting theory and hearsay with no personal experience or references.
Old May 22, 2004 | 12:00 AM
  #36
Richin Chicago
Default Re: When giving tech advice: (66ImpalaLT1)
Here is a reference:
http://www.trackaero.com/factors1.html
Notice the 8x to go from 100 to 200 MPH.
Old May 22, 2004 | 12:17 AM
  #37
66ImpalaLT1
Thats very interesting, but I'm not sure if thats entirely valid since you dont drive a 1 square foot plate.
To When giving tech advice:
Old May 22, 2004 | 12:19 AM
  #38
George8211's Avatar
George8211
:lolg: :lolg: :lolg:
Old May 22, 2004 | 12:55 AM
  #39
Richin Chicago
Drag is drag. Unless you alter the shape of the vehicle while going from 100 MPH to 200 MPH it is going to take around 8X horsepower to get there.
"Since rolling resistance force is not a function of speed, then rolling resistance horsepower (a function of speed) increases proportionally with speed. Since aerodynamic drag force is proportional to the square of the car's speed, then aerodynamic drag horsepower increases proportionally to the cube of the car's road speed."
http://kennedyp.iccom.com/pat/road-load.htm
[Modified by Richin Chicago, 12:05 AM 5/22/2004]
Old May 22, 2004 | 10:53 AM
  #40
Midwayman's Avatar
Midwayman
:withstupid:
yah physics!
