Elaborating of Tire Sensor Problem.
Old Jun 11, 2004 | 09:01 AM
2004C5Mitch's Avatar
2004C5Mitch
Default Elaborating of Tire Sensor Problem.
I think we are narrowing the problem down...
We cannot get the sensors in the wheels to calibrate using the instructions that were sent to me by West Coast Corvettes (Awesome guys!). We make it all they way through the process but it won't recalibrate (horn doesn't honk).
I think the issue might be that they are 2001 Z06 wheels, with 2001 style sensors on 1998 C5. Is there a known issue with them communicating?
Thanks!
Mitch
Old Jun 11, 2004 | 09:25 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: Elaborating of Tire Sensor Problem. (2004C5Mitch)
Thanks!
Mitch
Yes, it is well known that you can't mix the sensor styles...you need to keep the same style that came on your car regardless of what wheel you're using. You can use a sensor from a 97-2000 on your car.
2001-2004 style sensors won't work.
Old Jun 11, 2004 | 03:16 PM
2004C5Mitch
Default Re: Elaborating of Tire Sensor Problem. (Y2Kvert4me)
Thanks. I think he will just have to live with the sensors not working since the 1997-2000 sensors physically don't fit the 2001 wheel (can't get a good seal).
I appreciate your response.
Mitch
Old Jun 11, 2004 | 03:20 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Mitch
Just strap them / expoxy them to the center of the wheel, and use regular valve stems. Many CF members have done the same for custom wheels. If they are factory Z06 wheels, I know for a fact this set up works fine, since that's what I have on my car.
[Modified by Dan_the_C5_Man, 3:22 PM 6/11/2004]
Old Jun 18, 2004 | 06:41 PM
2004C5Mitch
Default Re: Elaborating of Tire Sensor Problem. (Dan_the_C5_Man)
Thanks Dan!
Mitch
Old Jun 18, 2004 | 09:11 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Same here. Remember where the sensors are since they will no longer be behind the valve stem. Also, when you do this, the standard GM magnet isn't strong enough for training. I'd suggest that you go to Radio Shack, buy their larges woofer speaker, tear it apart for the magnet and use it for training. (Another WCC tip for me that works great!!!)
[Modified by CAJUNY2KC5, 2:12 AM 6/19/2004]
Old Jun 19, 2004 | 10:43 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Default Re: Elaborating of Tire Sensor Problem. (CAJUNY2KC5)
I put mine 180 degrees from the valve stem hole , so I know where they are if I need to re-train them. Also, it's a good idea to take a few jpegs of them mounted on the wheel before installing the tire so you know exactly where they are. Use a 5 minute epoxy and prepare everything in advance (cleaning and sanding mounting area on both the wheel and the sensor) so you can whip through the process.
Old Jun 20, 2004 | 12:17 AM
AtHomeSoda's Avatar
AtHomeSoda
Wow... I have a 98.... with 98 sensors... and they are on the 2001 wheels, and fit fine, and seal... so does a friend of mine with a 98 and the new wheels... so... I am not sure what the problem is, other than you have the wrong sensors... I had a set of the 2001 sensors also, and they did not work, as they are different... but... the right ones seal, and work.... really
Old Jun 24, 2004 | 02:53 PM
2004C5Mitch
Default Re: Elaborating of Tire Sensor Problem. (AtHomeSoda)
I will pass the word. I appreaciate everybody's help!
Thanks again!
Mitch
Old Jun 24, 2004 | 07:13 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I installed 2002 sensors on my ZO6 chrome wheels. The little rubber seals looked very easy to damage and seemed like they would be prone to leaks. I applied a very light coat of permatex "BLUE" to the seal and I do not think it will ever have a problem.
Is your seal in good shape? If the sensor does not hit/rest on the rim when the stem cap is torqued in to place, the rubber seal should work and not leak.
If the sensor hit the wheel when the nut is tightened the stem could be cocked and the thing will never seal.
BC
Old Jun 24, 2004 | 07:21 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Mitch
The early style sensors WILL fit Z wheels...but the trick is you need the rubber seals from late model sensors. The early style sensors just used an O-ring to seal. The later style have a thick rubber washer that has a step in it. The smaller (stepped) part of the seal fits in the hole of the wheel...so later model wheels have a slghtly larger stem hole drilled to accomodate this. The actual stem diameter is the same for both tyle sensors I believe.
You could try your local dealer to see if you can buy just the sensor seals (for a 01-04 car)...but I do not know if they are avaiable alone (they normally come on new sensors, and they are reusable unlike O-rings, so it might not be available as a seperate part).
To Elaborating of Tire Sensor Problem.
