Pinging/Predetonation
Old Jun 26, 2004 | 03:00 AM
S1K C5's Avatar
S1K C5
Default Re: Pinging/Predetonation (GLENN43)
Pinging is NO GOOD< your motor is gonna eat the big cheese if you dont change that.
Old Jun 26, 2004 | 07:49 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: Pinging/Predetonation (S1K C5)
Mine was pinging before I got my cam installed...Mike Norris did the install and tuning..pinging went away ...I since installed a different airbridge and coupler..drove to CI...damn pinging came back...last year we got bad gas on the way up so we took fuel system cleaner this year..still pinging..I am pretty confident that the airbridge made the difference so I will most likely have to get some tweaking done on the programming side.
Old Jun 26, 2004 | 07:57 AM
jojog's Avatar
jojog
Default Re: Pinging/Predetonation (Macinamouth)
As I understand it - they are all prone to carbon buildup which is lessened by opening it up now and then. I found that BG44K kills the ping with one use. Do a google search for distributor in your area. $20 a bottle (fuel additive) but it removes most deposits AND cleans the sending unit for the fuel gauge. Try it - it beats taking your car to the dealer!
Old Jun 26, 2004 | 05:10 PM
vettman10's Avatar
vettman10
Cruise-In II Veteran
Default Re: Pinging/Predetonation (jojog)
CHANGE THE FUEL FILTER!! Believe it or not, this simple step has fixed many C5's with a pinging problem. How? When the filter gets dirty, it can act as a fuel flow restrictor when the fuel demand is high, such as during WOT operation, thereby reducing fuel pressure, which when in the PE mode will lean the mixture. I had pinging problems on my '01 for over a year, after reading a similiar post (like this one) I changed it. The filter was so blocked I could hardly blow through it. Then presto - pinging go bye-bye. That was 6 months ago and still no ping.
Old Jun 26, 2004 | 08:08 PM
yellow01's Avatar
yellow01
Default Re: Pinging/Predetonation (vettman10)
vetteman10 - great point/post!
I'm wondering now if that was my problem on my older '01... hmmm.
Old Jun 26, 2004 | 08:21 PM
Blkout's Avatar
Blkout
Not that I disagree with you that the fuel filter should be changed regularly, but I have yet to see one cause pinging, I have seen one so badly clogged that the car would barely idle.
Old Jun 27, 2004 | 02:11 AM
Dirty Howie's Avatar
Dirty Howie
Car only has 12K miles.....is this really a possibillity?
Old Jun 27, 2004 | 02:13 AM
Dirty Howie
How fast can carbon buildups occur? Car only has 12K miles.....is this really a possibillity?
Old Jun 27, 2004 | 07:26 AM
jojog's Avatar
jojog
IMHO - yes. All I really "know" is that the BG44K makes mine go away. I last used it about 6,000 miles ago but have dumped a bottle or two of Techron in it since.
Old Jun 27, 2004 | 11:52 AM
Z.06's Avatar
Z.06
Macinamouth-
Yes, I returned to 93 octane Mobil gasoline over 250 miles ago, and the pinging has gone away.
As explained by the dealer, my Z has no problem because (1) all of the engine control systems are working properly and (2) GM has no service bulletin that recognizes and offers a fix for my problem. This is also the reason given that I had to pay the diagnostic charge.
Apparently the extended warranty only covers repairs, so the diagnostic fee can only be reimbursed if the dealer does a repair (that is recognized by GM) to fix a problem. This is nice circular logic.
:mad
Old Jun 28, 2004 | 12:07 AM
Dirty Howie
Can you give me a link or phone no. where you get the BG44K. I use a lota Chevron that already has the Techron...Thanks
Old Jun 28, 2004 | 07:38 AM
jojog's Avatar
jojog
Try this link -
http://www.bgprod.com/home.html
Old Jun 29, 2004 | 01:19 AM
  #33
Dirty Howie
Thanks.....got a place right down the street from me....If I try it I will let you know if it helps.
Noticed all the MZB and Lexus dealerships are listed as service centers for their products.
Old Jun 29, 2004 | 07:41 AM
  #34
jojog's Avatar
jojog
They have a range of systems for cleaning and flushing various systems. All I have used id this additive for the fuel. This is top notch stuff! Good Luck -
