Rear Diff Fluid change - discuss
Old Jun 24, 2004 | 03:04 PM
Chopper Larry's Avatar
Chopper Larry
Default Rear Diff Fluid change - discuss
Figuring 24K is time to refresh the rear diff fluid (easy 24k miles);
What fluid did you use?
Friction modifiers, etc?
Technique or steps (I realize you drain it and refill it);
Will hand pump work?
Any other points of interest?
Old Jun 24, 2004 | 04:35 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: Rear Diff Fluid change - discuss (Chopper Larry)
Chopper; if you haven't had any issues with the factory fluid and the factory friction modifier - then why not refill with the same stuff again?
For filling, I attach clear tubing to the fluid bottles tapered spout, hold the bottle sideways, and just squeeze.
But just be sure the tubing is secure on the bottle nozzle; or you'll squirt diff fluid across your garage floor. Don't ask me "how" I know this :bb
[Modified by Mike Mercury, 4:35 PM 6/24/2004]
Old Jun 24, 2004 | 05:00 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
I used the Redline gear oil. It comes with the friction modifier included already.
Old Jun 24, 2004 | 05:20 PM
gonbad's Avatar
gonbad
Default Re: Rear Diff Fluid change - discuss (Umrswimr)
Remember to remove the fill plug then the drain plug otherwise when it drains it will slosh all over the garage floor. The old oil is thick, greenish black and smells real bad.
It is a major PIA to clean up and will stain anything.
I second the use of the Redline Gear Oil. They make two versions one with the modifier and one without. Just make sure you get the right one. You will need two bottles but you will barely use any of the second one. Just keep it on hand for the next change.
Old Jun 24, 2004 | 05:39 PM
Chopper Larry
I can barely hear a LITTLE SHORT grind or groan on a slow right turn...that made me think rear fluid.
I knew I could depend on you guys!
Gonbad....how's the big "D" still?
Old Jun 24, 2004 | 06:01 PM
gonbad's Avatar
gonbad
I finished grad school in December. I am trying to get out of here as fast as I can. Looking like back to Houston or New York City. If NYC then all the cars will go as I will live in Manhattan. That is the only drawback!
Old Jun 24, 2004 | 07:01 PM
vettenuts's Avatar
vettenuts
Default Re: Rear Diff Fluid change - discuss (gonbad)
Amsoil here, good results also. I also cover the rear spring before I start just in case. I wouldn't want to get that stuff on it.
Old Jun 24, 2004 | 07:55 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Default Re: Rear Diff Fluid change - discuss (vettenuts)
I'll be filling mine up w/ AMSOIL in a few weeks when I prep my car for Viperdays. It comes w/ the friction modifier in it allready.
Old Jun 24, 2004 | 08:05 PM
Autoworker's Avatar
Autoworker
I just changed mine a couple of weeks ago. Go to http://www.vetteshop.cc and click on "misc". They have GM 75w90 synthetic lube (2 qts) and GM limited slip additive. Their prices are great, and their service was better. I ordered on Saturday, and it was on my doorstep on Wednesday. You'll need a 10mm allen head socket for the top and bottom plugs. When you're all done, torque the plugs at 26 ft lbs.
Old Jun 24, 2004 | 08:46 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Default Re: Rear Diff Fluid change - discuss (Autoworker)
I use AMSOIL Series 2000 75w90 which has friction modifier in it. AMSOIL also makes a synthetic 75w90, which also has the friction modifier in it. Both are recommended and warrantied by AMSOIL for the C5/Z06.
AMSOIL does make a friction modifier (product code ADA), but my car doesn't seem to need it. My diff doesn't chatter with the Series 2000 75w90. FYI, AMSOIL rates this fluid as "fill for life" for normal service use.
I just changed mine out this weekend. Changeout is very simple once you get the right stuff. I use a $3 oil pump I bought at the local autostore to pump the fluid up into the diff (and I have another one for the tranny fluid).
More info on the AMSOIL product line can be found here:
Independent AMSOIL Dealer
AMSOIL Corporate Homepage
You can find the applicable AMSOIL products for any of your cars here:
AMSOIL Online Product Application Guide
Old Jun 25, 2004 | 01:19 AM
blackjack's Avatar
blackjack
For all of my cars...
Old Jun 25, 2004 | 07:38 AM
AFVETTE's Avatar
AFVETTE
I used AMSOIL and had some minor posi chatter, so I had to add about an ounce of SLIP-LOCK. Luckily I bought a bottle when I bought all my AMSOIL fluids. I had access to a buddies lift and fluid transfer hand pump. With that set up it took less than 30 minutes to change the tranny and diff fluids. The only difference I noticed was a slight reduction in tranny gear rattle on shut down and I think it feel smoother during shifting but that could have been the plecibo affect of doing a job like this.
Tom
Old Jun 25, 2004 | 07:50 AM
Richin Chicago's Avatar
Richin Chicago
Default Re: Rear Diff Fluid change - discuss (blackjack)
I use Reline for both the MN6 and differential. Have been using their stuff for quite a few years.
Old Jun 25, 2004 | 08:09 AM
Mr. Jones's Avatar
Mr. Jones
Default Re: Rear Diff Fluid change - discuss (AFVETTE)
i used Amsoil, i waited to see if I had any chatter. It did and then I
added the GM additive. I used a pump that mounted right onto the
quart bottles-a small plastic thing that has a plunger.
Old Jun 26, 2004 | 01:59 PM
carpe dm's Avatar
carpe dm
Remember to remove the fill plug FIRST, then the drain plug otherwise when it drains it will slosh all over the garage floor. The old oil is thick, greenish black and smells real bad.
To Rear Diff Fluid change - discuss
