Good replacement battery?
Old Jul 1, 2004 | 07:39 AM
theultimatep's Avatar
theultimatep
Default Good replacement battery?
My battery now will not keep a charge. I left the battery in my car during the cold winter and while it sat all winter long. Is there a good replacement to buy?
Thanks,
PAS
Old Jul 1, 2004 | 07:45 AM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In VI Veteran
Default Re: Good replacement battery? (theultimatep)
Optima Red...
Old Jul 1, 2004 | 07:46 AM
Miaugi's Avatar
Miaugi
Let me be the first to tell you what most here believe in, the Optima red top.
That is not what I did though, I stuck with an AC Delco, I got the AGM type to avoid possible acid leaks. Whatever you do, get a quality battery, your car will love you for it.
Old Jul 1, 2004 | 07:53 AM
ArmyVette's Avatar
ArmyVette
Default Re: Good replacement battery? (Miaugi)
Runs about $100 - $115 for the Redtop. The peace of mind is, however, priceless.
Old Jul 1, 2004 | 06:49 PM
theultimatep
Default Re: Good replacement battery? (Smoke-N-Shot)
Thanks for the info. I called a few places that have the optima red and they tell me that it's not for the vette?
Old Jul 1, 2004 | 08:31 PM
GTC's Avatar
GTC
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05
Those places don't know what they are talking about. An Optima Red Top is available in a size and with posts that work fine with a vette. Many people here run Red Tops.
Yes, the Red Top is probably the forum's favorite aftermarket battery. However, I went with an Optima Yellow Top. You can't go wrong with either.
Old Jul 1, 2004 | 09:01 PM
Oldvetter's Avatar
Oldvetter
I replaced my DELCO with a Champion XLT (AGM Battery) size/number DT35/CHXDT35 made by Exide. Got it at SAMS Club for $90-95. It has 690 CCA, 850 CA, a 36 month free replacement and free jump-start, and a 108 month limited warranty.
Old Jul 1, 2004 | 09:06 PM
leaftye's Avatar
leaftye
Default Re: Good replacement battery? (Oldvetter)
I got my Optima Red top at Costco. I've been using it since last fall.
If you want a lightweight battery, there's a decent one by Hawker/Oddysey/Genesis. It's the same battery sold under different brands. Several racers around here use it.
[Modified by leaftye, 7:08 PM 7/1/2004]
Old Jul 1, 2004 | 09:38 PM
Dave68's Avatar
Dave68
I've heard good things about this battery:
http://www.odysseyfactory.com/
...much lighter and in most cases, smaller than an Optima.
Old Jul 1, 2004 | 11:04 PM
FixedRoof's Avatar
FixedRoof
Default Re: Good replacement battery? (Dave68)
Optima is a great battery. My friend has one that he just cannot kill. Thats where my vote goins when mine goes dead. Hopefully awhile, since it's a relatively new AC Delco.
Old Jul 2, 2004 | 11:45 AM
powderski13's Avatar
powderski13
I replaced the dead Delco AGM which only has 500 CCA with an Optima Yellow Top 78/34 thats rated at 720 CCA
Old Jul 2, 2004 | 12:11 PM
Tim2K4Vert's Avatar
Tim2K4Vert
You want the Optima red top 75/35.
Old Jul 2, 2004 | 12:17 PM
jerrymcb's Avatar
jerrymcb
You also want to get a VDC Electronics battery minder or a
Deltran battery tender plus. You can leave either of these on the battery
when the car is not in use (especially winter) and forget about it.
This will prolong your battery life.
To Good replacement battery?
