tire pressure sensor question
Old Jul 1, 2004 | 03:37 PM
billiardcue's Avatar
billiardcue
Default tire pressure sensor question
I bought a second set of wheels and tires and pressure sensors.
If I program the new sensors to my car do I have to reprogram every time I change the tire/wheel package?
I am only using the new wheels and tires for the track - solo II and drag strip but I want the pressure sensors for the road trips to and from the tracks.
Old Jul 1, 2004 | 05:49 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Default Re: tire pressure sensor question (billiardcue)
As long as you don't mind doing your racing without tire pressure readings you won't have to reprogram the sensors after each wheel change. Just program the wheels you want to use for your road trips and as long as you return the wheels to their original corners you're good to go.
Old Jul 1, 2004 | 07:31 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bill
Make sure that the sensors are the same style as your stock sensors, 2000 and later are different than 99 and earlier and are NOT interchangeable!
BC
Old Jul 1, 2004 | 08:27 PM
GTC's Avatar
GTC
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
Default Re: tire pressure sensor question (Bill Curlee)
Bill
BC
but I think you are off by 1 year. I thought that 97-00 used one system, and 01-04 used a different system.
If you swap wheels/tires and want the DIC to read them, you have to go through the reprogramming step.
Old Jul 1, 2004 | 09:42 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: tire pressure sensor question (GTC)
You are CORRECT! Sorry for the mistake!
To tire pressure sensor question
