Want to Increase Power.
Old Jul 2, 2004 | 08:56 AM
resjoer's Avatar
resjoer
Default Want to Increase Power.
Ok, here's the deal.
Ignorant owner needs help.
I've been unable to get what I want for my '99 Automatic coupe so I've decided to have a little more fun with it.
First- I've heard that 385 HP is as far as you should take a '99 automatic...is that true?
Second - What mods give you the most bang for the buck? I'll probably change the mufflers for a more aggressive sound.
Any input would be appreciated.
Thanks,
Joe
Old Jul 2, 2004 | 01:28 PM
Dave68's Avatar
Dave68
Default Re: Want to Increase Power. (resjoer)
For the most part, a cat-back install is for sound (unless you really pump up the power at the engine, ala supercharger - then a lower restriction catback is a must). As for bang-for-buck power increase, a new intake system will give your engine a healthy bump at minimum cost. I've found that the new Halltech Stinger-R intake is the best deal out there at $199.00. It includes a massive air filter assembly, larger than stock airbridge, and smooth throttlebody coupler. You cab buy one through A&A Corvette. Of course, there are many other intakes available that will produce a nice power increase, but at higher cost and after more installation time.
Another popular choice among forum members is a gear swap. You won't see any dyno power increase, but seat-of-pants feel will be noticable.
Old Jul 2, 2004 | 01:49 PM
roscoe118's Avatar
roscoe118
Bottom Line:
More $$$/More HP
No, you shouldn't be limited to 385HP on an A4. I'm not an expert, but if you get over 400RWHP, you may need to upgrage the drive trian as well.
Welcome to the addiction
Mods Away
Old Jul 2, 2004 | 02:20 PM
mdhmi's Avatar
mdhmi
How fast do you want to go and how much are you willing to spend? After you add an air intake (Blackwing, VaraRam, whatever) and a catback mods start getting *very* expensive. My preference is a blower or turbos.
Mark
To Want to Increase Power.
