Cat/Back Install Questions...
Old Jul 2, 2004 | 10:34 AM
roscoe118's Avatar
roscoe118
Default Cat/Back Install Questions...
After searching through the Tech archives, I came away with a couple questions that were not clearly answered there.
1. With an MN6 on a lift will I still need to remove the sway bar to manuver the exhaust over the axel?
2. If I do, I'd like to confirm torque settings upon reinstall of sway bar.
From one thread:
49 lb./ft. for the top. Is this correct?
70 lb./ft. for the bottom. Is this correct?
These require a torx bit. Is this correct?
Thanks Guys and Have a Great 4th
Old Jul 2, 2004 | 12:29 PM
Patches's Avatar
Patches
Default Re: Cat/Back Install Questions... (roscoe118)
Yes, The sway bar still presents interference to maneuvering the intact muffler/pipe assembly away from the crossmember. Unbolting it only takes a minute.
From one thread:
49 lb./ft. for the top. Is this correct? Yes
70 lb./ft. for the bottom. Is this correct? Yes
These require a torx bit. Is this correct? No. Metric sockets and wrenches are all you need
:flag :flag :flag
Old Jul 2, 2004 | 12:30 PM
georgec114's Avatar
georgec114
YES... But no removal necessary. Leave the end links on and the bar will drop out of the way.
From one thread:
49 lb./ft. for the top. Is this correct? YES
70 lb./ft. for the bottom. Is this correct? YES
These require a torx bit. Is this correct? NO
...George
Old Jul 2, 2004 | 01:41 PM
roscoe118's Avatar
roscoe118
Thanks Guys!!!
To Cat/Back Install Questions...
