Leaking Differential on Z06
Old Jul 6, 2004 | 10:55 PM
Hydra01's Avatar
Hydra01
Default Leaking Differential on Z06
Does anyone have any advise regarding a leaking differential on a 2003 Z06 with 4980 miles on it? The fluid is relatively clear and smells like gear oil so I'm pretty sure it's coming from a leaking output shaft or the differential itself. I've seen some discussion on this forum about a vent but I can't get under the car far enough to see one. Do the rear axle(s) require re-alignment after a repair of this type? Also, should I expect the dealer to have lift pads (I don't have any). I sure don't want to see any cracks or splits in my rocker panels. I REALLY dread taking the vette into the dealer......is this an involved and difficult repair job? Any advise is appreciated! :flag
Thanks!
Old Jul 7, 2004 | 02:29 PM
mad99c5's Avatar
mad99c5
Default Re: Leaking Differential on Z06 (Hydra01)
MY 99 COUPE IS AT THE DEALER KNOW FOR THE SAME PROBLEM . I ONLY HAVE 29,000 MILES ON IT. I'LL LET YOU KNOW WHAT THEY TELL ME
Old Jul 7, 2004 | 02:37 PM
dbirdz06's Avatar
dbirdz06
My 02 with about 7000 miles had this problem. Turned out to be the right differential gasket. It wasn't something I thought I could fix. Took it to the dealer and they repaired it under warranty. They had to keep it overnight and took them 2 full days to fix, but I think they were busy. Didn't require re-alignment that I know of. Hope this helps.
Old Jul 8, 2004 | 11:24 AM
lively14's Avatar
lively14
When I had my catback system installed, the mechanic pointed out a leak in my driver's side diff gasket. In order to get at that gasket, unfortunately, you have to take off the whole rear end. The dealer (City Chevrolet, for those of you in the Charlotte area) quoted the job at aprox. $1,500.00. There aren't any puddles in the garrage yet, so I'm just holding off for now. I hate the idea of having a leaky diff, but its a REAL slow leak and I don't have the cash to pay for the repair nor the time/lift to be able to do the job myself.
Of course, my Vette has 76k miles on it now, so its not unexpected to start having seal problems. Sorry to hear about you guys with low mileage problems.
Good luck.
Old Jul 8, 2004 | 12:30 PM
hotrodhoodlum's Avatar
hotrodhoodlum
8th Gear
best ime to go gear change,,,,
Old Jul 8, 2004 | 12:43 PM
Mr. Jones's Avatar
Mr. Jones
i had the right output seal changed at 8500.
did the gears at the same time. if you don't
want a gear change just make your appointment
with the dealer. its a common problem, there are newer
seals ask them if they are using them.
Old Jul 8, 2004 | 09:03 PM
Orbit's Avatar
Orbit
Default Rear end oil leak
I had my Y2k start making a puddle on the garage floor at 7500 miles. Dealer replaced seals under warranty.
Old Jul 8, 2004 | 11:36 PM
VETFVER's Avatar
VETFVER
GM has manufactured parts to fix that common problem. Mine was done very early on and I've had no problem since.... knock on wood. The fact that my car doesn't leak is good reason to hang onto it, which I intend to do.
Take it to a dealer that has fixed a few ahead of you.
Dan
Old Jul 9, 2004 | 02:13 PM
mad99c5's Avatar
mad99c5
Default info from the dealer
the dealer told me that it was the drivers side gasket and it would cost about $650 and they told me to contact GM and complain, so I did and GM is going to pay for the whole cost of the repair.
Old Jul 9, 2004 | 02:49 PM
VetteSiNz's Avatar
VetteSiNz
Replaced gasket and seal after 6K miles on my o4 Coupe. Looks like a common problem on a vette. Better report it to http://www.nhtsa.dot.gov
Old Jul 9, 2004 | 07:03 PM
Dave68's Avatar
Dave68
I may have the same problem - noticed oil on the floor the other day.
Old Jul 11, 2004 | 09:29 AM
Hydra01's Avatar
Hydra01
Default Headed to the Chevy Dealership for repair!
As much as I hate to take the "Z" into the dealership I'm headed there in the morning! I've been putting a piece of cardboard under the differential for several days and I've accumulated quite a collection of drips, spots and oil puddles! CAN YOU IMAGINE HAVING TO PUT CARDBOARD UNDER A $50k CAR! It doesn't appear to be coming from the vent.....so that can only mean there is a leak somewhere from a seal or gasket. The drips and spots are concentrated on the left (driver's) side of the vehicle so maybe that will provide some useful information or be an indication to the mechanic at the dealership. I think I'm going to actually bring my "piece of cardboard" with me tomorrow to show them the amount and rate of leakage. I'll keep you guys posted on any progress.
To Leaking Differential on Z06
