I just picked up my 01 and now have it in my possession. I see that I once had a cd changer as the carpet in the trunk storage compartment is factory cut-out for one, and my option codes in the glove box say it was there.
Could someone with the original 12-changer installation, tell me where the wire harness is routed in the trunk area? Maybe mine is tucked out-of-sight, or cut off at a point. If I knew where it is supposed to be, I could search more inteligently without taking half the car apart.
Thanks!
Ron Dittmer
2001 Convertible, Bowling Green With Tan
Re: HELP!!! CD Changer Wire Harness...Where Is It? (Ron Dittmer)
The factory harness gets routed to the pass side of the car (it should be tied to RR taillamp harness) all the way to right side of the pass seat and to the BCM (under pass side dash footwell cover). Mike Mercury has posted about this subject. Do a search.
