Electronic Torque Wrenches - required?
Old Jul 8, 2004 | 12:04 AM
billiam01's Avatar
billiam01
Default Electronic Torque Wrenches - required?
These expensive ($400+) electronic torque wrenches are required for head R&R on LS1s. Anyone know of a way around buying these tools other than paying someone else to do the engine work?
Old Jul 8, 2004 | 12:13 AM
nuke61's Avatar
nuke61
Default Re: Electronic Torque Wrenches - required? (billiam01)
Eh? I thought all you needed was a torque/angle meter...
http://www.sjdiscounttools.com/lis28100.html
Old Jul 8, 2004 | 12:57 AM
J-Rod's Avatar
J-Rod
Default Re: Electronic Torque Wrenches - required? (nuke61)
Even easier. You get a regular torque wrench, and then after you torque the bolts, you marke the heads with a marker and turn them the appropriate number of degrees. That way you can track how far you turn them...
Old Jul 8, 2004 | 01:12 AM
BHP's Avatar
BHP
The Lisle unit for about 25 bucks works fine.
Old Jul 8, 2004 | 02:08 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: Electronic Torque Wrenches - required? (BHP)
Use a standard torque wrench. AutoZone sells an angle meter for about $12.
You dont need to get fancy. Torque is torque. If you have a quality torque wrench, you should be fine! The military requires that a torque wrench be tested prior to use. It's a good idea to clamp the torque wrench drive in a vise and cycle it past the torque that you intend to use. I have a click torque wrench and I always test it prior to use! Good practice that can let you know if the wrench is working.
BC
[Modified by Bill Curlee, 1:10 AM 7/8/2004]
Old Jul 8, 2004 | 09:27 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
BC
Thanks. Excellent point.
To Electronic Torque Wrenches - required?
