16 CODES & Several Messages :(
Old Mar 18, 2005 | 11:48 AM
Epicman's Avatar
Epicman
I'm having the same problem on a 2001 Z06. The passenger side door does not respond to anything. My friend checked the boxes by the firewall on the passenger side and said nothing was damp.
Sorry to bring back an old post but I thought this would be better than starting a new one.
Old Mar 18, 2005 | 12:48 PM
yellowvette837's Avatar
yellowvette837
St. Jude 15 Year Donor
St. Jude Donor '03 thru'19
Tampa Events Princess
2015 C6 of Year Finalist
I Believe In The Beer Fairy
The only solution I know it to replace the Right Door Control Module.
Don't know the cost, because mine was replaced under warranty. But I watched them replace it in the parking lot at work. It was not very difficult.
Hope this helps.
Don't worry about digging up an old post. Hell it was my post
Old Mar 18, 2005 | 01:11 PM
Epicman's Avatar
Epicman
Hope this helps.
Where is the passenger side door control module located? Is it just unplug and plug in the new one?
Old Mar 18, 2005 | 01:23 PM
yellowvette837
it is located behind the inner door panel. The module sit right behind the panel.
Yes it is unplug the old one plug in the new one.
Old Mar 18, 2005 | 02:40 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by vetracn98
I would like to hear this also since I beat your record with 23 Codes ( Many Codes!!! thread). It would help me ( a little)
Derek
You still having issues with your car??? Welcome back by the way!!!
Up-date me on whats up with your car.
Bill
[B]yellowvette837[/B]
Make sure that you battery is fully charged! The loss of communications codes happen when the supply voltage for each module goes low for what ever reason. Usually happens when starting the car after it has been sitting stored after a long period of time OR if you were playing the stereo for a while cleaning or vacuuming the car or parked listening to the radio while your waiting for someone to return.
Get the battery checked out and see if it has a good reserve capacity (able to maintain 12 VDC for a specified time and is able to recover quickly after discharge.)
Please let us know how things turn out.
Bill Curlee
Old Mar 18, 2005 | 02:56 PM
yellowvette837
Originally Posted by Bill Curlee
yellowvette837
The loss of communications codes happen when the supply voltage for each module goes low for what ever reason. Usually happens when starting the car after it has been sitting stored after a long period of time if you were playing the stereo for a while cleaning or vacuuming the car or parked listening to the radio while your waiting for someone to return.
This is my daily driver .
I never do this
Bill Curlee
I had the battery check bt 2 differnt places and they said it was fine. I still had problems so I purchased an Optima Red Top in Feb.....All issues seem to be fixed except for the Charge System Fault
You always have great answers Bill
Thank You
Old Mar 18, 2005 | 04:39 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
My 02 Z06 gets the same "Charging System" faults. Not too often but just every once in a while. I learned to ignor it unless it stays on or I get a check engine light associated with it. Strange, but my 98 almost NEVER had that fault.
I told my service department about it and they wrote it in my warrenty paper work and stated that it is nothing to worry about unless it sets a code or stays on.
Bill C
Old Mar 19, 2005 | 10:39 AM
yellowvette837
Bill C
I know to ignore it, but it still drives me
To 16 CODES & Several Messages :(
