Do Timing Changes Afffect A/F Ratios
Old Jul 16, 2004 | 08:53 PM
Earl H's Avatar
Earl H
Default Do Timing Changes Afffect A/F Ratios
Tuned the A/F ratio on the dyno. I wanted to take the car out on the street to test timing under load. If I add timing, will it affect my A/F ratio? Thanks in advance for the help.
Old Jul 16, 2004 | 09:37 PM
DTSNGIT's Avatar
DTSNGIT
Yes timing does affect A/F. If you added timing it will most likely lean out your A/F depending on how much was added.
Have Fun,
Mike
Old Jul 16, 2004 | 09:47 PM
Earl H's Avatar
Earl H
Have Fun,
Mike
Is there a rule of thumb, like 1 degrees equals .1 point of air fuel? Car is a stock cube forced induction car.
Old Jul 16, 2004 | 10:14 PM
DTSNGIT's Avatar
DTSNGIT
No general rule of thumb as there are way to many things to consider. It depends on many things like where you are already at in timing, if you're experiencing any spark knock, where your A/F was already etc...etc....
Mike
To Do Timing Changes Afffect A/F Ratios
