Fuel Pump Circuit
Old Jul 18, 2004 | 04:14 PM
CE2004's Avatar
CE2004
Default Fuel Pump Circuit
Does anyone (with a service manual) know what else is on the Fuel Pump circuit?
My buddy's 04 Coupe keeps blowing the FP fuse, and it's happened enough now that he has noticed that it occurs when executing a turn. A local Chevy dealer had the car for 10+ days and replaced the fuel pump and relay. 300 miles later it was back in their shop. Another 5 days in the shop, and they return it the second time. 3 hours later he had replaced the Fuel Pump fuse 5 times. Thankfully, the last one got him home. They also have cleaned all of the grounds on the car, and say that GM didn't have any records to indicate repeated problems.
Seems like something else must be on that circuit causing the problem?
Old Jul 18, 2004 | 05:30 PM
dpd's Avatar
dpd
i'm assuming you are popping fuse 13 in the fusebox under the hood[fuel pump fuse],if you are,look under the car at the 2 connectors and harnesses that are going to the fuel tanks and see if they are rubbing/hitting the exhaust.the fuel pump is the only load on this fuse.
Old Jul 18, 2004 | 08:58 PM
CE2004's Avatar
CE2004
Yes - fuse 13 - I think it's a 20Amp Mini fuse. From the symptoms, I think you're on to something with the fuel pump harness.
He's taking the car back to the dealer tomorrow. Sure would be nice if they put the car on the rack and found an obvious wire problem like that!
Old Jul 21, 2004 | 09:06 PM
CE2004's Avatar
CE2004
Here's the latest...
No obvious harness problem. Dealer used in-line 15 amp fuses to test the fuel pump harness. Apparently they ran an in-line fuse past the harness connectors, basically creating a straight wire from the fuse block to the fuel pump. The car continued to blow the 20 amp fuse on the fuse block, as described above, and the 15 amp in-line fuse(s) in the fuel pump wire were fine.
They are blaming it on the fuse block, and have ordered a new one. The dealer's tech said that they have had fuse block problems with some Cadillacs which they also sell. (Doesn't the CTS come from Bowling Green too?)
Seems strange, but their diagnostic method seems reasonable enough to make the diagnosis pretty legit. Any thoughts?
Old Jul 23, 2004 | 05:16 PM
CE2004's Avatar
CE2004
NO dice with the fuseblock. Still blowing fuses...
Anyone have thoughts on the cause? Saw another guy on the forum here having this similar problem... No apparent resolution to his problem either.
Old Jul 23, 2004 | 06:01 PM
VetteSiNz's Avatar
VetteSiNz
I just had mine fix today. The dealer found a bad connection that is grounding out to the chasis. Ensure have the dealer check all the way to the fuel pump. If the dealer use the inline to test the fuel pump, did they connect it to the fuel pump connector or all the way to the fuel pump? My car stalled on the highway (blowing fuel pump fuse #13) and I had my car towed to the dealer.
Old Jul 23, 2004 | 06:03 PM
dpd's Avatar
dpd
has anybody swapped out the fuel pump relay or tried to see if the fuse blows with the fuel pump relay out?if the fuse blows with pump relay out,the problem is either between the ignition switch and the fuseblock or you have a shorted fuelpump relay.you only have power to this fuse when you crank and when the car is running.only other possibility is from the relay to the pump,but this has been checked[?].
Old Jul 23, 2004 | 06:24 PM
CE2004's Avatar
CE2004
Same identical symptoms. His has done it enough to realize that fuse #13 pops when he brakes, or turns and accelerates.
I wonder what connection they found grounding out...???
When they replaced his fuel pump, I believe they replaced the relay.
Still a mystery...???
Old Jul 23, 2004 | 06:45 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
They need to examine the E N T I R E wiring harness for damage! Somewhere it is grounding out!
BC
Old Jul 23, 2004 | 07:35 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
"No obvious harness problem. Dealer used in-line 15 amp fuses to test the fuel pump harness. Apparently they ran an in-line fuse past the harness connectors, basically creating a straight wire from the fuse block to the fuel pump. The car continued to blow the 20 amp fuse on the fuse block,"
The PCM supplies the voltage to the fuel pump fuse and relay in the fuse box,so simply running a fused jumper from the fuse box to the fuel pump does not eliminate a short from the PCM to the fuse box,or an internal fault in the PCM itself
Old Jul 23, 2004 | 08:28 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The dumb a$* that designed that test needs to go back to flipping burgers at Mickey D's Examine the harness ALL the way from the fuse to the pump! You will find that the wires are pinched against something or rubbing each other.
BC
Old Jul 23, 2004 | 11:10 PM
Southview's Avatar
Southview
I guess John will be getting a good deal on the new c6 from Ken Dixon after all this.I know he ready to give up on this one.
Old Jul 24, 2004 | 08:01 AM
CE2004's Avatar
CE2004
They just need to fix the problem. At least one other report of the same problem, and they found a harness grounding out. Apparently, it's quite a gremlin to find...
Old Jul 27, 2004 | 02:34 PM
CE2004's Avatar
CE2004
Apparently, the dealer has located the problem. They said the fuel pump wire(s) runs over the transmission, and it didn't slide down into the notch for the wire, and rubbed through the conduit and wire. Hopefully, they finally nailed it!
To Fuel Pump Circuit
