Cut Ti Exhaust
Old Jul 20, 2004 | 06:24 PM
LA VIDA's Avatar
LA VIDA
Default Cut Ti Exhaust
I came across a good deal on a cut Ti exhaust and am considering upgrading (well sort of) my stock C5 exhhaust. Has anyone heard of any problems or drawbacks of welding the over the diff pipes to the cut Ti Exhaust?
Old Jul 20, 2004 | 06:40 PM
HalfMoon's Avatar
HalfMoon
Call around, I found here that a set I was offered that they attempted to do the "A&A mod" on wasn't worth it at $100. I couldn't find a mufflershop that could weld it locally.
I think you'll be better off buying a set like I did, that wasn't cut.
Old Jul 20, 2004 | 07:51 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Takes special equipment to weld Ti correctly!! Skip it and find a set that is NOT cut!
BC
Old Jul 20, 2004 | 08:06 PM
Patches's Avatar
Patches
BC
Old Jul 20, 2004 | 08:24 PM
SnowyATX's Avatar
SnowyATX
Welding Ti is a little tricky and requires an inert gas environment, like argon, as well as Ti filler metal for their TIG welder. Most shops will have no clue how to do this or have the setup (in my opinion). Probably ought to pass it up.
Old Jul 20, 2004 | 08:32 PM
MrEracer's Avatar
MrEracer
You cannot weld titanium to any other metal so if you are thinking of welding the titanimm mufflers to your steel tubes, forget it. The guy that sold these to you should have told you about this problem. He knew this because I told him about it.
Shirl
SDRE
Old Jul 20, 2004 | 08:36 PM
SnowyATX's Avatar
SnowyATX
Shirl
SDRE
ooh...missed that part.... you cannot weld your existing stainless pipes to the Ti muffler pipes.
Old Jul 21, 2004 | 07:31 AM
LA VIDA's Avatar
LA VIDA
Thank you all for the advice. Sounds like this "good deal" is not really such a good deal!
To Cut Ti Exhaust
