so im getting the afr's at 66cc. i have the fm11 cam. do i mill the heads or not? i dont want to flycut the pistons. how much power would i be loosing if i didnt mill the heads. i just dont wanna put the heads on and them have to take them off after. what is the minimal i could mill the heads and be safe with the fm11 cam? sorry for all the questions i just wanna do this right and once
Why don't you get them milled to 60 or 62 cc? All the shops I know of are getting their heads millled to that or similiar spec. 62 cc is delivering a 11:1 compression ratio. Can't answer your cam question, but the popular grind seems to be 224/228 581/...... 112-114 LSA. Contact Tony at AFR> He'll be happy to recommend a good cam.
I'm going with a smaller cam for an A4: 220/224 581/581 115 LSA for an ultra smooth stealth idle Best,
The sad part is you will have to install 1 head with an old gasket and check P/V clearance to get the right answer.Many things attribute to how much clearance you have including valve size,depth valve is seated in the head,ect. Better than shaving the head,install the setup and then bend all the valves on startup because someone said "it should be fine"
A couple of other things to consider along with ptv clearance when milling the heads are:
1: You will need custom length pushrods.
2: The intake manifold will sit lower and the space between the heads will increase. I'm not sure how this would impact manifold port to head port matching, but I suspect alignment may be a slight issue.
I would be nice if AFR produced a head with different cc volumes, like Patriot. This way you could choose the compression ratio you want and still maintain ideal geometries.
I would not mill the heads too much. With the 115 lsa your static compression is going to be very high ~ 240 to 250. It will make it very hard to tune.
As far as I know, AFR will produce any size CC anyone orders, within reason, of course. LG ordered one with a 59 cc, A&A gets 62 cc. The AFR standard spec is 66 cc and 76 cc, but I don't know why anyone would ever want a cumbustion champer of 76 cc. Anyway, you can have it your way no extra milling required. Best,
didnt LG say you could order them at different cc volumes for like 80 bucks extra?
the ones they put on their test car were 59cc i believe
That would be great, I didn't know that. I thought the 59cc combustion chamber was achieved by milling the heads .030. If that is the case I would just order a set at 64cc and be happy. I'm going to call AFR and find this out.
I just got off the phone with AFR. They gave me interesting info. THey have found that GM's deck tolerances vary up to +-.025", and that they use varying thickness head gaskets to maintain the proper CR. They also told me that they found you can remove .035-.040" without manifold fitment issues., so that is one thing less to worry about. What needs to happen is you have to pull the old heads off and check piston to deck height, then figure gasket thickness, and finally set yourmilled height. THey found that they had a .030" milled head set that detonated terribly and one that worked fine. They discovered this deck height issue while sussing the detonation. I think Cometic makes varying thickness gaskets. Sheesh! I thought I was all set to do my h/c and knew what to order. Back to the drawing board.
Damn, me too. I thought I was all done learnin' I was going to go 62cc by way of milling and run my C1 cam. I did not anticipate any "deck height" varience that could potentially screw everything up. I am not motivated enough to assemble one side to check or try out a bunch of different gaskets. I thought people were milling all the time the only concern being either P/V clearance (cam size) and octane requirements.
Damn.
Damn.
mtv
The big chamber would help ALOT in a Forced Induction app. It'd lower the compression, so you could crank the boost up without detonation/KR.
No way man it always pays to dic* around for more HP, It is just a matter of how much dic'*ing and what type. The 66 AFR's run 10.25:1 which I believe is less than stock. Somebody set me strait if I am wrong here.
If this deck varience is true wouldn't everyone be running slightly different compression STOCK and what with all the folks running milled heads and GM heads with all the different gaskets on F & Y bodies, I wonder why this does not come up more often - I'm not saying I doubt it, I know gaskets themselves can effect compression. I wish a vendor would close the loop on this. Good thread though !
[QUOTE=ArKay99]I just got off the phone with AFR. They gave me interesting info. THey have found that GM's deck tolerances vary up to +-.025", and that they use varying thickness head gaskets to maintain the proper CR. They also told me that they found you can remove .035-.040" without manifold fitment issues., so that is one thing less to worry about. QUOTE]
I can understand the production tolerance of +/- 0.025" for the deck to TDC piston height. But I find it difficult to believe that GM's automated engine assembly process has the capability to measure this tolerance and select a different head gasket based on a 6 sigma distribution model for every LS1/6 engine built since '97. . . I also don't think that an extra 0.025" of quench means the difference between zero KR and serious detonation.
Finally, AFR should know enough to mill the intake mounting surface the same amount as the deck to ensure proper intake manifold fit. Otherwise the intake will sit too high between the milled heads.
There's got to be more to the story. . . Do you have that AFR number available? TIA!!
