History codes keep coming back?
Old Jul 21, 2004 | 05:46 PM
NYtoCA's Avatar
NYtoCA
Default History codes keep coming back?
I've had codes in the past that have gotten fixed but every now and then the check engine light appears and when i go through the codes they all have an H next to them so i'm assuming that means history.
Why do these keep popping up after i clear them out?
Thanks in advance,
Frank
Old Jul 22, 2004 | 01:18 PM
NYtoCA's Avatar
NYtoCA
Anyone?
Old Jul 22, 2004 | 05:06 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
What are the #'s? If they are 1096 and 1064 don't worry about them, but these would not cause a CEL.
Old Jul 22, 2004 | 05:10 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
It's because your car has a history of posting these codes which means that they havent been fixed...
Old Jul 22, 2004 | 05:20 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
See also:
http://forums.corvetteforum.com/showthread.php?t=867251
Old Jul 23, 2004 | 05:55 PM
drdoc22's Avatar
drdoc22
Default Erasing the Codes
I took me three times to erase my history codes on my 98'.
Don't know why - but I followed the directions on the Forum, and it worked.
Doc
Old Jul 23, 2004 | 06:58 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You need to post the codes that keep coming back. Some of them happen when you have a weak battery. (Battery will start the car but voltage gets low enough to cause certain modules to set codes). As soon as the voltage geta above the threashold of low voltage the code goes to HISTORY
Use a volt meter and measure across the pos and neg battery terminals. When the car is cold have someone starts the car see how low the voltage goes as the engine cranks. It should not drop below 11 volts.
If the car sits for long periods of time between uses the battery could be good but just needs to be charged prior to use.
Let us know how you make out
BC
Old Jul 24, 2004 | 03:22 PM
SFVetteman's Avatar
SFVetteman
Also keep in mind that for your convience and amusement, Gm has made it so that some codes that indicate they are history are really current
Old Jul 24, 2004 | 03:37 PM
silverminevette's Avatar
silverminevette
Cruise-In V Veteran
Cruise-In VII Veteran
St. Jude Donor '03-'04-'05-'06
To History codes keep coming back?
