suspension squeak?
Old Jul 22, 2004 | 12:31 PM
breabob's Avatar
breabob
Default suspension squeak?
I have a squeak in my 6spd C5. Once I drive it for a couple of miles it appears. It sounds like it might be in the right rear but I am not positive. Any tips?
Old Jul 22, 2004 | 04:30 PM
leaftye's Avatar
leaftye
Please elaborate on your problem.
Here are a couple questions with possible problem areas for you to consider:
Is it speed or rpm sensitive? <-- hubs/e-brake/calipers
Does it change when you engage the brakes? <-- calipers
Does it change in intensity or frequency when you corner left or right, brake, or accelerate? <-- hubs
Is it constant with no breaks, or does it pulse? <-- hubs/e-brake/calipers
Have you noticed a difference on hot or cold days? <-- hubs/e-brake
Has your rear discs been taken off for service lately? <-- e-brake/calipers
Eugene
Old Jul 22, 2004 | 05:29 PM
Donnymac's Avatar
Donnymac
Have a simmilar squeak in the rear. Only occurs over small bumps with speed over 20mph.
Open to ideas........
Old Jul 27, 2004 | 04:25 PM
breabob's Avatar
breabob
It Does It Over Bumps While Driving Down The Roadover 20 Mph. Where Would Be Good Places To Spray It?
Old Jul 27, 2004 | 06:16 PM
Z11409's Avatar
Z11409
Lubricate both front and rear sway bar insulators.Check that all shocks are tight on the top end.Then start lubricating the rear suspension grommets.
Old Jul 28, 2004 | 02:14 AM
leaftye's Avatar
leaftye
Might as well get a washer and shim the sway bar bracket. Those things are way too tight, but the shims will still allow you to torque them down properly.
Old Jul 28, 2004 | 01:44 PM
breabob's Avatar
breabob
will do thank you
Old Jul 28, 2004 | 02:19 PM
add's Avatar
add
Default Squeaks
I bought some siliocn grease from Napa, and removed and lubricated the bushing, then reinstalled. Took about 20 mins, car is nice and quiet.
TD
Old Jul 28, 2004 | 02:53 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Common problem with the sway bushings
Old Jul 28, 2004 | 03:10 PM
Donnymac's Avatar
Donnymac
Thanks fot the tips. Will lube this weekend.
donnymac
To suspension squeak?
