Too much anitfreeze???
Old Jul 26, 2004 | 10:20 PM
CYA-Vett's Avatar
CYA-Vett
Default Too much anitfreeze???
After my header install, I topped off the oil and antifreeze, I filled it pretty close to the top. Should I drain some? I noticed after I drove around for a while, I removed the lid and there was alot of pressure in there.
Old Jul 26, 2004 | 10:26 PM
ArKay99's Avatar
ArKay99
There is a line on the side of the coolant overflow tank. You should fill it to there.
Old Jul 26, 2004 | 10:27 PM
leaftye's Avatar
leaftye
There should be pressure. The pressure raises the boiling point of the coolant.
Old Jul 27, 2004 | 06:00 AM
vettenuts's Avatar
vettenuts
Fill it to the line. I know someone who did an overfill and it damaged the tank. It needs the air pocket for expansion.
To Too much anitfreeze???
