Installing Backup lamp switch??
Old Jul 28, 2004 | 12:44 PM
00Rocket's Avatar
00Rocket
Default Installing Backup lamp switch??
Hey guys got a question? I have tried seaching but came up with nothing but here goes. How hard is it and what do I need to do to change the backup light switch? I am having the problem with no backup lights and I need to get my car inspected ASAP! I checked the bulbs and also the fuses and dont think the problem is with them. Thanks in advance for your help!!
Old Jul 28, 2004 | 03:35 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you have an MN6 the bad back up switch is a prettu common failure! I had to do the one in my 98 once! It is easy and requires nothing more than a common metric wrench! Jack the rear of the car up (JACK STANDS ARE A MUST) or get it up on a lift! the switch is on the passengers side, unplug the wiring harness, unscrew the switch and screw in the new one! I plugged mine and depressed the ball actuator to make sure that the new switch was good! Tested SAT!!
BC
Old Jul 28, 2004 | 08:35 PM
wreakhavoc's Avatar
wreakhavoc
Can you get the switch at any parts store or dealership only?
Old Jul 28, 2004 | 08:39 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I had to get mine at the dealer because it failed right after the warrenty and not a lot of autoparts stores carried C5 parts! C5's have been around a while and you might want to give the auto parts stores a try!
Old Jul 29, 2004 | 08:31 PM
wreakhavoc's Avatar
wreakhavoc
I got one today at Autozone for about $10. A 7/8" SAE deep socket fits it perfectly.
Old Jul 29, 2004 | 09:23 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You saved your self about 25 bucks!! Good job!!
To Installing Backup lamp switch??
