Muffler Bolts Pushed into Bumper?
Old Aug 1, 2004 | 02:18 PM
out2run's Avatar
out2run
Default Muffler Bolts Pushed into Bumper?
Can't believe I managed this..........
When installing the Borlas, I pushed the bolts that attached the muffler to the lower bumper up into the bumper.
Now I can't hang the mufflers
Any suggestions?
Old Aug 1, 2004 | 03:08 PM
1FUNC5's Avatar
1FUNC5
get one of those retractable magnets and drag them back to the holes...... I have done this before as well
Old Aug 1, 2004 | 03:11 PM
out2run's Avatar
out2run
I will give that a try. Are the bolts connected together?
Old Aug 1, 2004 | 04:50 PM
vettenuts's Avatar
vettenuts
Join the club. I think they are joined like a "U" bolt. I managed to fish mine out after I did the same thing. Suggest you leave the car, swear for a while to get it out and then try and get the bolt (that's what I did). I also think from the factory the center of the "U" bolt is fastened, so if you look in the hole you may see the bolt and be able to carefully ease it back to the hole. Kind of a dumb design if you ask me.
Old Aug 1, 2004 | 05:05 PM
out2run's Avatar
out2run
I have tried several magnets, plus tried hammering the bumper with a rubber mallet to help move the bolt. However, my hand is now messed up and cut up from the heat shield and still not visible. Still am swearing over the problem and will take the rest of the day off. You guys have much more drive than me!
Old Aug 2, 2004 | 04:01 AM
turboo2u's Avatar
turboo2u
Any suggestions?
This happened to me 2 months ago. There are suppose to be retaining washers to keep this from happening, but if the mufflers have been off a few times, the washers have probably fallen off. Unfortunately, I had to pull the bumper to reach my hand in thru the backbone of the car to get the hangers out. It's a hassle but it can be done in about 2 hours. Use a friend to lift the bumper as not to scratch it. INSTALL THE WASHERS WITH REINSTALLATION to avoid the problem again.
Old Aug 2, 2004 | 07:59 AM
lowdowndirty's Avatar
lowdowndirty
Will removing one of the tail light housings or the reverse light housing provide any access?
Old Aug 2, 2004 | 10:36 AM
out2run's Avatar
out2run
Sounds good, Any instructions on how to remove the rear facial? I will try using a bendable magnet first, but may ahve to remove the "butt" as suggested.
The lock washers, how are they attached? I don't recall seeing any? Could they also be inside the bumper?
Old Aug 2, 2004 | 12:11 PM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
Yes they are. They appear to be a wide shallow U-bolt.
Old Aug 3, 2004 | 01:29 PM
out2run's Avatar
out2run
Default Got It
Went back to bumper with a homemade (magnet piece on coat hanger)magnet assembly, as well as a retractable magnet from auto zone.
I was able to latch onto the bolts with the curved magnet and drag one end to the other bolt hole. Then took the other magnet and was able to pupp the one bolt out! Used fingers to position the other bolt out the hole! Took about 2 minutes..........
I think it is pure luck to have found the bolts.
Its also amazing what a relaxed attitude can bring to one when correcting our guffy mistakes.
Old Aug 3, 2004 | 02:46 PM
vettenuts's Avatar
vettenuts
Yep, thats why I walked around and swore for a while
Glad you got them out
To Muffler Bolts Pushed into Bumper?
