Oil Filter
Old Aug 3, 2004 | 09:54 PM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
Default Oil Filter
I know this is an old old topic, but I can't find it anywhere in the forums. What is the preferred oil filter for the LS1 (2004)? For some reason I thought there was a Mobil 1 filter but the guy at Advance Auto parts said he didn't know that Mobil 1 sold filters. If they don't, which is the best to use?
Tom
Old Aug 3, 2004 | 10:04 PM
BHP's Avatar
BHP
Delco PF46. Work fine every time.
Old Aug 3, 2004 | 10:10 PM
LoneStarFRC's Avatar
LoneStarFRC
Tom
Check with L.A.P.D. or Ken Fichtner Chev for the Delco UPF44. This is the premium Delco filter preferred by many members. (You may have to order a case lot of 6 though) As far as I know, Mobil1 still makes a filter for the LS1 but I don't have the part number. Maybe someone else will chime in here with it. HTH
Robert
Old Aug 3, 2004 | 10:13 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Old Aug 4, 2004 | 12:01 AM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
K&N HP1007 is a very good filter and has a handy nut on the bottom making removal a piece of cake.
Old Aug 4, 2004 | 12:26 AM
GrayC5's Avatar
GrayC5
Robert
I use the UPF44 also. And yes, Mobile 1 does make a filter for the C5 but I don't remember the number either.
Old Aug 4, 2004 | 12:28 AM
painexpert's Avatar
painexpert
UPF44.I bought a six pack from West Coast Corvette.They are $12.95 each.
Old Aug 4, 2004 | 12:39 AM
Bill Reid's Avatar
Bill Reid
GM UPF44
Old Aug 4, 2004 | 05:31 AM
vettenuts's Avatar
vettenuts
Check the following link:
Oil Filter Study
I recently pulled off my UPF44 and threw it in the garbage can. Now running a Balwin B31 and my oil pressure is much better.
Old Aug 4, 2004 | 05:40 AM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Baldwin B31 is an excellent filter - same as the AMSoil filter.
Oil Filter Study
Old Aug 4, 2004 | 10:57 AM
Red C6 Z06's Avatar
Red C6 Z06
Oil Filter Study
When you say that your oil pressure was "much better." what do you mean? Was it higher, lower or more constant (less variation)? And does the oil pressure sensor sense pressure upstream (between pump and filter) or downstream (between filter and bearing journals) of the filter?
Old Aug 4, 2004 | 12:23 PM
BHP's Avatar
BHP
Oil Filter Study
I would rather use PF46. The UPF44 has too much of a pressure drop. Never have liked it.
Old Aug 4, 2004 | 12:28 PM
Dave00C5's Avatar
Dave00C5
What kind of pressure drop have you noticed?
Old Aug 4, 2004 | 12:55 PM
LRD VDR's Avatar
LRD VDR
Anyone tried a Wix?
Shahram
Old Aug 4, 2004 | 01:17 PM
RushThruLife's Avatar
RushThruLife
But the nut hangs lower than anything on the car! Don`t hit a manhole cover .
Old Aug 4, 2004 | 01:33 PM
roscoe118's Avatar
roscoe118
Will the PF46 fit on an '02? I think I read somewhere that the PF46 was for '03 and newer. Am I or not?
I'm actually have a PF46, that I bought one day while at Pep Boys, but have not yet tried to install it.
Old Aug 4, 2004 | 03:08 PM
Last C5's Avatar
Last C5
Default Mobil 1 Filters
Mobil 1 does have a filter. It's number M1-107 and available from Auto Zone and Mid America to name a couple sources. I use them and they have increased the oil pressure 2 to 4 lbs over the stock filter.
To Oil Filter
Old Aug 4, 2004 | 04:15 PM
SPDaylightFan's Avatar
SPDaylightFan
K&N HP-3002
Old Aug 4, 2004 | 04:24 PM
vettenuts's Avatar
vettenuts
I noticed about a 5 psi difference at hot idle. Also, I am now curious when the weather cools off whether the oil filter was playing a role in the startup tick that everyone complains about, especially when the oil is cold. Will get that answer in a couple of months when the temperature starts to drop.
Old Aug 4, 2004 | 04:26 PM
silverz06vette's Avatar
silverz06vette
$13 each thats about double of what gmpartsdirect.com charges.
