The tube you want is only about 4 inched long with a 90 degree bend at the top where it slides onto the nub at the firewall. It is right behind the passenger side cylinder head. There is a possibility it may not even be there.
There are 3 other tubes like the one you have pictured on the drivers side that you should also check.
Scott
Thanks a lot, Scott. Will now have another try.
Frederik
Update: I finally found it, thanks to Scott. This A/C tube is very small.
Frederik
I have pictures of the 90 degree drain line fitting and a shot of where it is if you view it from the top (engine compartment) and the windshield cowl drain tubes.
[IMG]
[IMG] [IMG][IMG] [IMG]
The drain tubes highlighted by flashlight in fenderwell area.
There IS a forth drain hose for the Cowl drain. It is on the passengers side too.
As for the fourth UTTER, It is a L O N G black hose and you will need to pull the passengers wheel well access off to see it. It is all the way in the back against the fire wall and it is behind some of the wiring harnesses. You can take out the battery and see the tube! It is a little bit bigger in diameter than the other utters. You can NOT service it from the battery well area. All you can do us see it. You will end up finding it in the wheel well access area easier if you find it in the battery area first and have some one wiggle / move it.
I have yet to find any trash in that one but I continue to check it.
Feel free to e-mail me if you have any other questions.
ok I found the tube got it off from the top these things are really hard to get too what is gonna happen if I leave the dumb thing off the drain tupe for ac ive dropped it twice errrrr
