Trouble code (28-TCS) C1283
Old Aug 4, 2004 | 11:02 PM
TriniJoe's Avatar
TriniJoe
Default Trouble code (28-TCS) C1283
After Magnacharger installation, I am continually receiving trouble code C1283 (28-TCS). The message flashing on the DIC is 'Act handling warming up' then 'Service active handling', then 'Service vehicle soon'. Has anyone experienced this problem. I have a list of the trouble codes but C1283 is not in the list.
Old Aug 5, 2004 | 12:54 PM
dperretti1's Avatar
dperretti1
C1283 is Excessive Time to Center Steering. I would check that the sensor (don't know where it is exactly) was not damaged or disconnected during the installation if the super charger. I know they have to do a bit of work in the area in front of the radiator area, which is very close to the steering linkage.
Have you tried to rest and clear the code?
Old Aug 5, 2004 | 03:42 PM
TriniJoe's Avatar
TriniJoe
Thanks for the info. The crank was pinned without removing the steering rack. Does anyone have a manual & knows the position of the steering wheel position sensor on a 98 with active handling. The code was reset & cleared but it returned when I drove the car.
Old Aug 5, 2004 | 10:25 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The sensor is on the steering shaft at the base of the steering wheel (in the drivers foot well area) down near the fire wall.
If the steering shaft was disconnected and the wheel was turned the sensor is out of alignment. I know that you said that they didnt disconnect the linkage but you may want to ask them again.
BC
To Trouble code (28-TCS) C1283
